Old 12-13-2005, 09:08 PM
newbicivic89 newbicivic89 is offline
DPFI to MPFI
I want to do a minime swap cause i dont have the money to afford the whole swap right now so what do i need i want a d16y8 head and intake and distributor can someone help me cause i need to convert over to MPFi from DPFI any websites or pictures would be grate help. Also would a d16y8 minime swap work on a d15b2 block. If not then what would.
Old 12-13-2005, 09:32 PM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
Re: DPFI to MPFI
http://www.4thgenerationcivic.com/how-to's/mpfi_conversion.htm
That will get you through the MPFI swap. As for the Mini -me, do a search for it in the 88-91 civic forums and you should be able to find some info on it if no one posts anything on it. Because I don't know that much about it, but I think the y8 will work, but not for sure.
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 12-13-2005, 10:16 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
Re: DPFI to MPFI
yes the y8 will work but if you want to use hte y8 distributor then you gotta convert to obd1.
my friends site with his mini me
http://www.angelfire.com/dc2/cyber13/minimeinfo.html
Team Lonely Drivers
Old 12-14-2005, 04:21 AM
CrxFreak91 CrxFreak91 is offline
Re: DPFI to MPFI
you also have to change the timing belt. changing to a mpfi is fun.. you better be good at electrical.. i started to do mine but then had to have my dad help, he is very smart when it comes to electric. but do alot of research on it first. and dont listen to the instruction on using the factory wires for the fuel injectors just run four new wires to the ecu as i went through three hard to find ecu's til i figured out that one wire was bad in the injectors
Old 12-14-2005, 05:55 AM
Hybrid1990crx's Avatar
Re: Re: DPFI to MPFI
OBD1 huh? If he wants to run obd1 he has to run a z6 dizzy.
Old 12-14-2005, 05:58 AM
Re: DPFI to MPFI
dont listen to crxfreak. sound like he doesnt know wiring. its not hard at all. you just how to be able to read form a book which wire is wire. cut, strip, and crimp or solder. not that hard. ive done 3 dpfi-mpfis before, its not that hard. and if the factory wires were no good, why did honda use them in the first place. listen to the guys that actually did it themselves and know what there talking about.
Team Lonely Drivers
Old 12-14-2005, 06:05 AM
Re: DPFI to MPFI
dude wtf are you talking about? I didnt say anything about the wiring. all i said was that the y8 dizzy is obd2.
who said anything about the factory wires being no good? Not me. I would never tell anyone to run new wires when you can just use the factory ones. But you still have to run new wires for the 2 new injectors.
Also, how do you know what I've done, or what I can do? Wiring is a way easy if you have the diagrams and pinouts for the plugs.
Also, don't crimp, thats for hacks, always use solder and shrink wrap to keep out moisture and avoid corrosion.
Old 12-14-2005, 02:00 PM
Re: DPFI to MPFI
hybrid, plz look at the first question in that post, i believe it says dont listen to crxfreak, not hybrid1990crx. i wasnt even talking about you. but on that note i like how you didnt get pissed off in your writing. i always solder my connections but some people dont like too even though like you said soldering is best. also sorry about spelling i was alittle drunk when i wrote that
oh and orignal poster, if you want to use the y8 dist you need to convert to obd1. dont listen to hybrid1990crx about needing a z6 dist because he doesnt know what hes talking about, about that issue. you can use both dist the z6 and y8 but you dont need a z6
Team Lonely Drivers
Old 12-14-2005, 08:45 PM
Re: DPFI to MPFI
ok then, explain to me how you are going to use the y8 dizzy while running a p28?
Old 12-14-2005, 09:30 PM
so your thinking that the y8 since its obd2 wont work with a obd1 p28 ecu right? wrong. obd2 dists can work with obd1 ecus
Team Lonely Drivers
Old 12-15-2005, 09:45 PM
duffman868 duffman868 is offline
Re: DPFI to MPFI
^ i have heard this too because all you need for an dobd2-> obd1 swap is a conversion harness and ecu
1990 Honda Civic std - ls swap
1994 Eagle Talon dl - daily driver and slow as balls
I should make a paper mache turbo and manifold.. I shall call it.. the SSAutoMache
Old 12-15-2005, 09:55 PM
Re: DPFI to MPFI
ok to clarify this, this is not heresay its fact why you might ask. because i converted my car to obd1 using a 92-93 pr4 and i am running a obd2 ls distributor cause my motor is a 96. so it works
Team Lonely Drivers
Old 12-16-2005, 06:44 AM
Re: DPFI to MPFI
thanks, good to know. learn something new every day.
Old 12-16-2005, 06:54 AM
Team Lonely Drivers
