Old 12-13-2005, 07:01 PM
couplems2003 couplems2003 is offline
problem with starting
i recently replaced the distributor and rotor and broke some vacuum lines. i repaired the vacuum lines and now it wont start. my plugs were wet with gas when i checked and were pretty fouled. what can i do to get this car running again. it will crank but wont turn over.
Old 12-13-2005, 07:44 PM
CamarosRsweet94's Avatar
CamarosRsweet94 CamarosRsweet94 is offline
Re: problem with starting
What year is the car and what engine is in it?
1994 3.4L Chevrolet Camaro - No more
2006 Hyundai Sonata
Old 12-13-2005, 08:30 PM
Re: Re: problem with starting
91 305 tbi
Old 12-13-2005, 10:52 PM
bag91's Avatar
bag91 bag91 is offline
Get new plugs and start over.........
91 RS Camaro V8 305 TBI
cold/ram 14"/3" open element
K/N filter
3.73's
B&M Megashifter
180 thermostat
Flowtech TERMINATOR Exhaust
3" exhaust cutout
Silvania Silverstar Headlights
Ronal R15 Firehawk Wheels
Hankook Ventus Sport (front)
Sumitomo HTR+ (rear)
275/40ZR 17 all around...
_____________________________
Old 12-14-2005, 01:55 AM
supervisor1886's Avatar
supervisor1886 supervisor1886 is offline
Banned
you messed the distributor too much. wrong timing or no spark
1 check all conections to it
2 get a spare spark plug and connect to any wire and then crank. See if it sparks.(if not-missing conection)
3 if there is a spark pull the distributor out and #1 spark plug - ask someone to crank the motor in short bursts while u plug the spark plug hole til your finger is pushed with the air. (compression stroke). Grab a socket and rotate the engine a bit so the mark on the dumper lines up with 0 on the little scale. Put the distributor in. Look inside first-you have to mesh the gears and the bottom part of the shaft should go into the slot. (in can be adjusted with a big screw driver). The distributor should be completely down which can be hard to reach because in rotates a few inches when you mesh the gears. Check if you crossed any wires.
4 Should start right up.
