| Off-Topic Talk about anything other than cars. |
MBC leaking
alright i searched and couldnt find an answer for this
i have a turboxs standard mbc i did a compression test today and i had a tiny leak where the intercooler pipe connects to the intake manifold but, i had a very big leak on my mbc. it has 2 rubber round gaskets that go on the outside ridges of it, and under one of them it has 2 machined holes in it, and thats where all the air is coming out my question is= are mbc's supposed to leak, and if not, should i buy a new one or what?
The Real Deal Apexi N1 Exhaust, Apexi GT Downpipe, GREDDY Type-S BOV, Dejon Intercooler Pipes, TurboXS MBC, Injen Intake, JL Audio
Re: MBC leaking
I have the same one, now I am curious as to if mine is leaking. But to answer your question no they are not supposed to leak. Try http://www.joepmbc.com/ Good MBC's for a good price I think I might pick one up as well. I have a feeling this MBC might be the cause of my boost problems. In fact as I wrote this I bought one. If anyone would like my old turbo xs one send me a pm and You can have it.
1991 GSX 2.3 Stroker |
Re: MBC leaking
My Turboxs boost controller leaks too and I thought about buying a JoeMBC. Maybe they are supposed to let air off to control the boost? Although mine wouldn't change the boost at all so its pretty pointless.
-Brian
Re: MBC leaking
Hmmmmmm.... leaky Turbo XS BOV's and MBC's? Red flag there, thanks guys. I would have to second the JoeP MBC, Mike got one. Hes a nice guy and great product. Thats whats going on my DSM when I get one.
Re: MBC leaking
I believe the Turbo XS MBC's are bleeder valves, so they bleed off boost to raist boost levels. You want a ball and spring type of boost controller, such as the JoeP.
I have a JoeP and I don't creep at all, even with an unported evoiii. Very good and cheap BOV
now - 2000 civic soon - 2002 is300
Re: MBC leaking
All modern MBCs are ball and spring, including the turboxs. They will also ALL have a hole between the valve and the wastegate actuator. It's there so the WG can close
Kevin Jewer RWD Talon - 7.92 at 180 Mightymax - 10.7 at 125 |
Re: Re: MBC leaking
-Brian
Re: MBC leaking
Yes, ball and spring units are better than bleeders, mainly because the ball/spring valve stays closed until the set boost pressure is hit. This make them tend to spike more, but a prper spring rate and other variables can limit it. Turbo XSs are known for spiking more than Halmans or Joe Ps. I like the Joe P personally.
The hole is supposd to be there, and it will leak during an intake pressure test. I usually block off the MBC when testing so it doesn't make it hard to find the real leaks.
