Old 12-13-2005, 06:32 PM
jimmyv-21's Avatar
jimmyv-21 jimmyv-21 is offline
lower cfm's when heater on?
got the o1 gp gt with 3.8 and dual climate control
when i move the gauges to heat, the blower seems to "kick it down a notch". but when i have them on cool, they blow normal. are the cfm's supposed to be lower when the heat is on? i tried searching this and could not find any posts. thanks ahead of time
Old 12-16-2005, 11:22 AM
StevePT StevePT is offline
Re: lower cfm's when heater on?
Just a general guess since I've never had a GP heater box apart, but I've had other vehicle's heater boxes apart... There's flappers inside the assembly which actuate depending on your heat setting and the output direction.
I have noticed that when you go from FULL Cold to FULL Heat there is an "audible" difference in the amount of air coming out of the vents.
However, the cold/hot control is independent of the motor so it's not actually slowing down the motor, it's just the direction the air has to take might be a bit more restrictive than the "fresh air" direction.
