Old 12-13-2005, 05:31 PM
don154 don154 is offline
another 4x4 problem
i have a 94 s-10 blazer 4 door with push button 4 x4 . this vehicle was sitting wrecked for about a year. it was given to me and i have made body repairs. i was told the 4x4 worked when parked. when the key is turned on both lights on switch come on then go off. while sitting still and in nuetral i can hit the 4 hi button and no clicks , no light comes on, nothing. if i hit 4 low both lights come on then just the low light when it engages. it will go into 4 low. is the problem the switch or something else.
Old 12-13-2005, 07:12 PM
Sen Sen's Avatar
Sen Sen Sen Sen is offline
Re: another 4x4 problem
I have the exact same problem.
but no answer on how to repair this.
94 Blazer S-10
1st Gen-4wd
4.3L W V6
Faster and louder than stock, but nonetheless a blazer!
Old 12-13-2005, 07:33 PM
come on guys. anybody that can help would be appreciated. thanks
Old 12-13-2005, 09:01 PM
Sen Sen's Avatar
Give it some time. a lot of the forum members don't log on everyday.
94 Blazer S-10
1st Gen-4wd
4.3L W V6
Old 12-13-2005, 10:16 PM
s10blazerman4x4's Avatar
s10blazerman4x4 s10blazerman4x4 is offline
Send a message via AIM to s10blazerman4x4
i remember reading about an encoder motor going on the case.Search encoder motor see what comes up.
1991 Chevy S-10 Blazer 5.7 V8 RIP
1999 Chevy Blazer 2dr 4.3
Old 12-13-2005, 10:19 PM
http://www.s10extremist.org/tech_art...ctronic4x4.htm
Read up on that. I think that might work for you guys especially since the first one said it wouldnt go into 4hi but would gointo 4lo
Old 12-14-2005, 09:33 AM
Cailen Cailen is offline
Sounds like the switch. If you had a problem with the encoder motor the 4hi button would flash and he'd hear an audible click.
Go grab one of those switches from a wrecker. They pop out of the dash real easy, no need to take anything apart.
Originally Posted by blazee
If you would pull your f ing head out of your f ing ass and read the f ing thread, you will see that I posted the most common f ing cause in f ing post # 4 and Swalt followed it up with more f ing details in f ing post # 8. From what we f ing posted you should be able to f ing realize that if you have two new f ing tires on the f ing front and two raggedy ass f ing tires on the f ing back... that is probably causing your f ing bang. Try not to be such a tool. Can you do that, Thank you. f head!
Old 12-14-2005, 11:54 AM
I believe had the link been read it also names said switch and what not and i got from that motor could be bad because he has same problems as that link.
Old 12-14-2005, 12:52 PM
red94fourdoor red94fourdoor is offline
Send a message via AIM to red94fourdoor
I copied the following from s-10 forum. I see a lot of member having problems with their electronic transfer cases not allowing their 4 wheel drive to work.
All this info helps as well that I wrote on another forum:
Well, through everything I have gone through with this electronic 4x4, I figured I would share my knowledge as best as I can. If anyone thinks something should be added, feel free to. This is also from gathered information on other posts.
***HOW TO CHECK WHAT IS WRONG***
You will probably know when your 4x4 has failed when you needed it in the mud pit. Mine, for instance, failed by not doing anything when I hit the 4HI button. However, it would go into 4LO.
To read the codes for the 4x4 with electric shift transfer case, install a jumper wire from terminals "J" and "A" on the ALDL (12 pin connector under the driver's side dash)
The lights on the 4x4 indicator (switch) will flash in a pattern, there are only 4 codes, one flash is code one, 2 flashes is a code 2, and so on...
Code "1" is "RAM standby power" and is considered normal, may be caused by clearing the codes.
Code "2" is "Encoder fault"
Code "3" is "TCCM motor circuit"
Code "4" is "RAM/ROM failure"
If you have the codes 2 or 3 check all the encoder motor connections at the transfer case, if OK it will need a new encoder motor assembly.
If you have code 4, replace the TCCM.
Make sure all connections are good and no corrosion, and then it's either an encoder or TCCM.
***TO FIX THE TCCM***
The TCCM is located behind the glove box, and is accessed from underneath the dash. To remove, the kick panel and black cover come off. Then a 1/4" screw holds the "brains" in the dash. The middle computer is the Truck's brain, the one on the backside is the TCCM, and on the front is the small ABS computer. Simply loosen the 2 10mm nuts on each side, and they will separate.
***WAYS TO FIX THE ENCODER MOTOR PROBLEM.***
This is the most common problem, and was my problem.
Cheap way - To clear the codes and reset the computer, pull the 5 amp TCCM fuse, located at the bottom of the fuse box. Wait at least a half hour, and then replace the fuse. Turn the ignition key to run, wait for the 4x4 lights to blink, and then turn off. Repeat 5 times, and then start the truck.
Decent price way - I just went and bought a rebuilt encoder motor from a company off of Ebay. Their company is www.northernautoparts.com The part cost me around $140 with a 1 year warranty and $38 core refund when I send the old one back.
Expensive way - buy a brand new one from GM for over $300.
***HOW TO INSTALL THE NEW ENCODER MOTOR***
Lucky way - Only thing that needs to be removed is the encoder motor itself. Tools needed are a 10mm hand wrench and a 8mm and 10mm socket wrench. The 10mm socket will work on the upper and lower bolts, while the regular wrench is needed for the middle bolt. (Tight squeeze). The 8mm socket is for the electric plug.
Then, just pull out, and wiggle it out of the truck. Install in reverse order.
Unlucky way - This means the encoder motor did not just wiggle out. Now the front drive shaft will have to be removed at the transfer case. Then, a yolk puller is needed in order to remove the yolk from the transfer case. Once this is done, go to the directions in lucky way.
This is as much knowledge as I have at the moment about the beautiful setup called the electronic pushbutton 4x4. Thank you to all that have helped me, and hopefully this will help others in fixing the future.
-=Glenn=-
I wish to Thank Glenn aka gmshades from s-10forum.com
I followed everything and I finally figured out what was wrong.
Thanks Glenn
Old 12-14-2005, 02:36 PM
Also what the link says
