Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 12-13-2005, 05:04 PM
lentinman lentinman is offline
Changing Brakes
Is there a special tool required to push the cylinder back so that I can fit the new brake pads on. I was told that I could do it with a clamp, but someone else said there may be a specific tool required. I have a 95 Saturn SL1.
Thanks, Len
Old 12-13-2005, 05:43 PM
peppermrj's Avatar
peppermrj peppermrj is offline
Re: Changing Brakes
Thanks, Len
A c-clamp is fine for the front. If you have rear disc brakes you do need a special tool. The pistons sort of screw in. You can get a cheapie that looks like a metal box about an inch square. It has pins on all sides. Certain pins will match up with your pistons. You use a 3/8ths ratchet to turn it and the piston inward.
Old 12-13-2005, 06:31 PM
Re: Re: Changing Brakes
Thanks for the response. I started doing it and I ran into an immediate problem. I cannot get the bolts to come loose that hold the whole caliper assembly on. I don't want to break anything, but I have yanked on the wrench and hammered on the wrench. They don't screw in the opposite way from normal do they?
Thanks again.
Len
Old 12-13-2005, 07:00 PM
peppermrj's Avatar
Re: Changing Brakes
right tight left loose. Remember to take into account you are not facing the bolt heads.
http://www1.autozone.com/servlet/UiB...3d8019acf0.jsp
Old 12-14-2005, 09:51 AM
saturnspeed_12's Avatar
saturnspeed_12 saturnspeed_12 is offline
yeah thats the biggest problem people run into with brakes. see looking from the outside, you would be turning it to the right. yet if you are under the car it would be left to loosen. yeah there is a brake caliper tool, its like $4 and then for quite a few gm cars, normally no longer newer ones, you have to use a special tool the turns the piston while shoving it in since the parking brake is apart of the caliper. on newer cars they use a drum style parking brake.
