Old 12-13-2005, 04:58 PM
tsmurphy72 tsmurphy72 is offline
trans temp sender in Pressure Port?
Looking to see who has done this and seen no problems and is it safe? I have been searching many post. People are using the pressure port on the 4L60E for the temp sender. I was worried about the depth of the sender. Will it block a passage? Has anyone seen the inside of the trans? I checked the depth of the port and it is real close. The sender tightens in and there are no leaks. I am concerned that the added length of the sender could block a passage inside. Some gauge manufactures state to install in the pressure port. I have not had a 4L60E apart to know how the protrusion of the sender effects anything inside the trans. The other solution is to weld a bung into the pan. I looked into the instrument cluster route but to expensive. Nothing is ever easy. Thanks for the help
Old 12-14-2005, 09:06 AM
Bob B Bob B is offline
Re: trans temp sender in Pressure Port?
Hi,
The pressure port seems to be an ok place from what I've seen.
I looked at three gauges from NAPA but the temps were too compressed in the operating range to be clear while driving.
Then I visited a speed type shop and saw the B&M gauge.
B&M has been a tranny beef up company for years.
It was perfect. It comes with a mounting housing also.
The gauge number range is easy to read and has color code background.
The sender mounts in a tee that you cut into the fluid line.
It really put my mind at ease while towing my fifth wheel trailer.
Bob B
