Old 12-13-2005, 01:44 PM
cc10is cc10is is offline
dashboard warning light
94 3000gt-
A light has been on on my dashboard and im not sure what it means, or how to fix it. It the yellowish one on the bottom right right below the SRS light. I dont have the owners manual, so could someone help me out?
Old 12-13-2005, 04:19 PM
WReX WReX is offline
Re: dashboard warning light
does it look like a box with waves in it?
if its the one i'm think it means you need washer fluid
26 PSI anyone?
Old 12-13-2005, 05:34 PM
or its the gazebo looking thing, which i think is for the adjustable wing on the vr-4's?
26 PSI anyone?
Old 12-15-2005, 04:20 AM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
hope this helps:
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
