Old 12-13-2005, 09:19 AM
randywirtzfeld randywirtzfeld is offline
Windstar timing cover leak?
I have a 96 Windstar 3.8L, there is a external coolant leak after you take it out on the interstate and run it hard. It looks like its coming from the timing chain cover? Does the timing chain cover seal any coolant passages? Its not coming from the water pump, but further in, between the timing chain cover and the block? Unless I'm missing a leak up top and its running down to this area, but I don't think so.
I see my repair manual recommends teflon sealant on one bolt that goes through both the water pump and timing chain cover. If the threads were not sealed anymore wouldn't the coolant follow the bolt up to the bolt head and leak there?
Thanks,
Randy
Old 12-13-2005, 10:35 AM
DRW1000 DRW1000 is offline
Re: Windstar timing cover leak?
I certainly do not know for sure but I think I remember someone mentioning that they replaced the water pump and did not put sealant on one particular bolt and then they had to remove it and add the sealant because of leaking.
You may be onto something
Old 12-13-2005, 01:55 PM
Winny_the_Pooh Winny_the_Pooh is offline
Randy,
I sympathize with you as I also have a '96 with a 3.8L and , also, I do not have good news for you. There are actually 2 coolant passages through the timing chain cover to the block from the water pump. Unfortunately, this engine has a history of leaks in this area, presumably from the gasket itself. There are also 5 stud bolts that go through the water pump and timing cover to the block, one of which goes into the water jacket on the block.
If the gasket has failed, you will probably also leak coolant into the oil pan. If you drain the oil and the first fluid out looks reddish brown, you probably have coolant in the oil.
I took on this repair myself about a year ago. It is do-able for someone who is reasonably handy but, in my opinion, was even more involved than the head and lower intake gasket repair (which I did two years ago). So, unfortunately, I speak from first hand experience.
Good luck and let us know if you have any other questions.
George
L
Old 12-13-2005, 04:24 PM
wiswind wiswind is offline
I was quoted $1200 by my dealer to replace the timing cover gasket. They said that the part is cheap.....so it was most all labor.
I had a seapage at that location...and....I believe at the lower intake gasket. As the leak was a seapage.....I added some Bar's "Stop Leak" to the radiator. I prefer the "Liquid Alluminum" or the other kind that is similar. I did use the "pelletized" type once.....but found it hard to add as the transmission cooler is right under the radiator cap...which made adding the pelletized form difficult.
I change my coolant each year.....and keep the correct dosage of the Bar's Stop Leak in the coolant at all times. Has kept the leak under control for several years.
The first time that I changed the coolant......and did not add the stop leak product.....I developed the slight leakage again....after about 6 months.
I changed my thermostat this past summer.....and it....and everything around it was spotless clean....no deposits of any kind.
I would recommend sticking with one of the products under the Bar's brand.
Old 12-14-2005, 05:16 PM
[quote=Winny_the_Pooh]Randy,
George
Thanks for the reply. I also did the head gasket repair about 3000 miles ago. Sounds like I will have to bite the bullet and repair this now. What's the laundry list for this repair?
Water pump
water pump gasket
timing cover gasket
crankshaft seal
oil pan gasket(I assume this needs to be removed?)
Anything else?
Thanks,
Randy
Old 12-14-2005, 05:51 PM
According the the instructions that I read....you need to drop the oil pan...which requires dropping the "Y" pipe....which is the one piece unit that contains the 2 catalytic converters.....and pipes to the exhaust manifold, and up to the flex pipe that is right in front of the big square muffler.
Instructions tell you to be careful not to miss the bolt that is hidden behind the oil pump.
Check out the instructions at www.autozone.com
They say to remove the engine from the car.....several people have posted that they did the job without doing that.....but you DO have to raise the engine up a few inches to be able to clear the frame member with the water pump pulley.
It looks like you have to mess with the pulleys on the front of the engine....and the oil pump......
Also...from what I read....the new FORD gaskets are improved....so as to not fall apart.....like the original ones did.
My leakage was not bad enough to even make any drops under the car....so I was lucky.
If you have a digital camera......could you take pics and post them?.....this is a VERY common failure...and I know that many people would be helped greatly by pictures and instructions from your experience. I may be one of them in the future if the leaks come back.
Old 12-14-2005, 09:10 PM
Randy,
I went back over my notes and here is the material I purchased
1) Timing Cover Gasket Set. I used Felpro P/N TCS45951 and it included:
a) timing cover gasket
b) water pump gasket
c) oil pump gasket
d) crankshaft front seal
e) the larger o-ring in the water pump inlet to seal the lower tube to the radiator ( I believe. There is also a smaller o-ring on an upper tube into the wtop of the water pump. Between the timing cover kit and the water pump, I got both of the o-rings I needed).
f) RTV
2) Oil pan gasket set. Felpro set includes:
a) rubber gasket for rear main seal
b) lotsa RTV for the rest of the gasket
3) New water pump (includes gasket, so now you have two)
4) Timing chain and timing gears (judgement call - I figured why not since I had it apart).
5) coolant
6) Teflon thread sealant
7) vibration damper puller (rented)
8) power steering pulley puller (rented)
9) New stud bolts from Ford (judgement call)
10) New gasket for exhaust pipe (depends on where you decide to unbolt the back end of the exhaust)
11) Maybe consider a new belt if it's been awhile.
12) anti-sieze compound (for exhaust bolts)
13) petroleum jelly (to repack oil pump)
14) I find a Haynes, Chilton, or Ford shop service manual helpful.
15) it's nice to have a parts washer. I use a cleaner called Hurri-safe in mine. Bought it over the web.
Wiswind is correct, you have to lower the exhaust to get at the oil pan conveniently (and you are correct, you have to lower the oil pan to free the bottom of the timing cover). You can do the job in the car but you do have to remove the nuts to the two motor mounts on the passenger side (front and back) and jack up the engine to get the water pump and pulley to clear the wheel well. I had the car up on three jack stands and removed the passenger side wheel to help with access to that side of the engine.
You will also have to remove the CMP to get the cover off. As you probably know, the CMP timing is critical. I set my engine to TDC on #1 and never let it move until the CMP was back in. Plus, I made careful notes on the position of the CMP vane (with the cover off) and the position of the CMP body ( the body where the hold-down washer is positioned will be clean and gives you a reference when you are re-installing it).
If you decide to tackle the job, I have more thoughts on things to watch for. This reply is a little verbose so I will cut it short for now. But, please let me know if you would like to hear more.
George
Old 02-13-2006, 10:20 AM
George,
I am going to take on this repair tommorrow. You mentioned you may have a few more tips for this repair, fire away, I could break a rubber ball, in a rubber room.
Thanks for the initial reply also,
Randy
Old 02-13-2006, 11:48 AM
LeSabre97mint's Avatar
LeSabre97mint LeSabre97mint is offline
Originally Posted by randywirtzfeld
George,
Randy
Randy
While you have your crossover pipe off you may consider replacing your Vehical Speed Sensor (VSS). This part isn't very expensive, but when it goes bad the trannie doesn't know when to shift,......the cruse doesn't work
It's in a tough place to get at and dropping the Y pipe is helpful.
MHO
Dan
Wiswind's Windstar repair pics http://community.webshots.com/album/201931518cScpNK
Photos of my repairs: http://dansautopictures.shutterfly.com/
Check this out:http://threewheelmotorcyclemetro.shutterfly.co
A must read about problems Windstars have: http://www.automotiveforums.com/vbul...d.php?t=672854
95 Windstar 240,000+
98 Windstar 136,000+ 09-25-2008.
85 Dodge 1 Ton Snow mover gas hog
91 Mazda Protege free beater
SW MN
Old 02-14-2006, 05:04 PM
I started this job and already realize I made a mistake. How do you correctly reposition the camshaft position sensor? I marked the base on the outside by the hold down bolt but I neglected the taking the cover off the top and marking the placement of the vane that turns inside the top. My repair manual makes reference to an alignment tool for this purpose, but where would I get one, every time I go to a dealership for a specialty tool they give my the cold shoulder. I doubt any of the places like Checker or Napa would have one? Or could someone describe how the vane should be positioned with the Number #1 cylinder at TDC?
Randy
Old 02-14-2006, 08:27 PM
12Ounce 12Ounce is offline
Randy,
Those tools are available from SPX- OTC tools.
http://www.otctools.com/frames-catalog2.php3
Look under "engine service" ... I think the part number for your engine is 6469.
Another method is find a friend with your year model Windstar with a 3.8 ... move the crank until cyl #1 is at TDC. Pull off the cam pos sensor and have a look.
Old 02-15-2006, 10:01 AM
I bit the bullet and bought the tool off ebay. Thanks.
Old 02-19-2006, 10:30 PM
Randy,
If you have the engine set at #1 TDC, then the vane will be on the right hand side (with you standing at the front bumper and looking back to the rear of the engine/firewall). The vane turns CCW so the "leading edge" will just be entering the notch/cutout in the rear of the housing and the "trailing" edge will just be about to enter the front notch in the housing. If you then clamp the hold-down washer on the same place of the CMP housing (based on your mark or, in my case, the clean/dirty areas), you should be very close.
As you lower the CMP into the timing cover, it will have a tendency to spin slightly as the gears engage. So, you may have to preset the van a litte bit earlier than the desired final position so that it spins right into where you want it.
I used this verbal description from a poster on Cartrackers.com by the name of Wrestler and I was able to get the CMP positioned correctly. If you are close, the worst that may happen is that the engine may hesitate slightly on acceleration. If so, you can slightly adjust the housing until this goes away.
I hope this helps.
BTW - How far along are you? DO you already have the cover back on?
Old 02-20-2006, 07:47 AM
Randy,
I sent you a powerpoint slide and a picture of my CMP position in seperate e-mails. The second e-mail had a little problem getting out initially but I think I got it to go. Please confirm if you did not receive these two e-mails and I will resend.
George
PS - If anyone is willing to post these on the web somewhere for the masses to use, please e-mail me and I will forward them to you.
Old 12-11-2006, 09:05 PM
jakethebt jakethebt is offline
Any updates to this or new tips? It looks like my gasket gave up the ghost. I will try and put it off with some stop leak... but it sounds like I will be changing the gasket too.
Question... when you jack up the engine in the van after loosening up the mount bolts, can you get it high enough with the transmission and axle shafts still in place?
