| Search | Car Forums | Gallery | Articles | Helper | Air Dried Dog Food | IgorSushko.com | Corporate |
| Latest | 0 Rplys |
Show Printable Version | Email this Page |
#1 | |
2004 Jeep Liberty Gas Milage
I just purchased a used 2004 Liberty. Last week (or at least my last tank of gas) I averaged 16 mpg. There is no reading in my car that says what I am getting.... (I used miles/gallons at fillup) to figure it out.
I did use the four wheel drive more on the last tank due to the amount of snow we recieved, but I think the car will not be doing much better than 16 mpg. Doe anyone have information on ways to increase the mpg I get? PM me if you want Thanks in Advance |
#2 | |
![]() Join Date: Jul 2005
Re: 2004 Jeep Liberty Gas Milage
Most areas are now using 10% ethanol mix for the winter. This can cut your mileage by 10-20%. My mom traded in her Liberty because at best she could only get about 20mph (she drives slow too). If you are getting 16 on 10% Ethanol mix, you are still in the ballpark for mileage. If you are like the rest of us, and start your Jeep and turn the heater on (it's about 20 decrees F. here in the morning) for about 10 min before driving, that can reduce your mileage even more. My Jeep has dropped to 18mpg with the cold weather.
#3 | |
Pontiac Guy
![]() Join Date: May 2004
I just read this post and I had the same issue with an 03 Liberty. The best I ever got was 20 mpg in the middle of the summer on a trip. Usually got 15 to 16 mpg in normal driving. Ended up trading the Jeep on a Chrysler Pacifica. Gets better mileage and has a whole lot more room. Sorry for the late reply.
#4 | |
MPG's
My stock 2004 gets 17 mpg around town and 21.5 on the highway. I average 24 on a long trip to the beach and 22 on the way back.
How many miles you got? I would suggest checking the air filter and spark plugs. You change your oil and oil filter, I recommend using 5W20 thibker oils have be known to leave build-up on the return ports. Some fuel injector cleaner probably wouldn't hurt. |
#5 | |
I just got around to reading your reply's thanks for the info.
the jeep is low on miles 31 k ... I never thought about using 5w20 for oil... do others do this as well? I could change the spark plugs but thought it shouldnt need that yet... once again thanks for the info |
#6 | |
You might want to check your spark plugs. I've heard of several people having to replace them below 30k. I've noticed about .5 mpg increase since I've switched to 5W20.
The only other ways to improve MPG is to reduce weight and/or increase aerodynamics. Chrysler did a pretty good job on the 3.7L and it's almost impossible to squeeze anymore hp or mpg's out of it. Some other options would be a cold air intake. The idea is colder air is denser, the cheap ones don't work, you want one that has a heat shield, I recommend K&N. A betterflowing exhaust can help as well. At the moment no one make headers, so that would be your choke point and the intake and exhausts won't be as effective as they could be. You could also add an underdrive pulley, more efficient torque converter (if it's an automatic) or change your gearing. Throttle body spacers, chips and tornado kits (swirl the air as it's coming in) are snake oil, don't waste your money. Most of the mods are done for omcreased performance, not increased mpg's. You will get a slight increase in mpg's, but if you are doing this to save money at the pump it's not worth it. You'd have to spend about $1500, for a very small (less 2 mpg, maybe less than 1 mpg) increase. Imagine how many miles you'd have to drive to offset the cost, well over 100,000. |
#7 | |
thanks for all the info... i think i may change the oil... and def replace the spark plugs
#8 | |
My Liberty was getting 18 until I got a K&N air filter, now getting 20mpg
