Go Back   Automotive Forums Car Chat > Ford > Contour
Old 12-13-2005, 08:58 AM
CTdameis CTdameis is offline
98 contour random misfire help
I have a 98 contour 6 cyl 2.5, the computer says it has a random misfire
i changed all the plugs and wires its a random misfire so i dont think its the timing i dont want to buy a computer or coil till im sure thats the problem
Old 12-13-2005, 09:05 AM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
Just make sure the wires are secure to the coil pack and some sort of electrical grease is applied to the contact point of the spark plugs and spark plug wires.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 12-13-2005, 09:25 AM
it says the missfire is in cyl #1,2,and 3. i dont know if that makes a difference. so your sure its not the computer or coil?
Old 12-13-2005, 09:27 AM
o and by the way thanks for your help
Old 12-13-2005, 10:01 AM
Re: 98 contour random misfire help
are you sure all 3 wires are in the correct order?
"The CEG Nazi"
www.contour.org
Old 12-13-2005, 10:29 AM
Re: Re: 98 contour random misfire help
yea i used the manual to make sure
Old 12-13-2005, 01:18 PM
any other ideas?
Old 12-13-2005, 03:39 PM
any other ideas?
could be a coilpack issue, but i just find it hard to believe that all 3 cylinders on one side of the engine are all misfiring. Does it misfire constantly or just every now and then?
"The CEG Nazi"
www.contour.org
Old 12-14-2005, 08:15 AM
Re: Re: Re: 98 contour random misfire help
every time i start it but its not constant, i can feel it hesitating uasualy when i stop then go.
Old 12-14-2005, 08:55 AM
Re: Re: Re: Re: 98 contour random misfire help
when you replaced the spark plugs did you gap them accordingly?
"The CEG Nazi"
www.contour.org
Old 12-14-2005, 09:54 AM
Re: Re: Re: Re: Re: 98 contour random misfire help
is the ignition module located at the bottom of the coil pack? but yes all the plugs are gaped accordingly and all the wiring is correct.
Old 12-14-2005, 10:06 AM
Re: Re: Re: Re: Re: Re: 98 contour random misfire help
also it couldn't be a problem with the plugs or wires because it had this problem before i changed them
Old 12-14-2005, 10:40 AM
Re: Re: Re: Re: Re: Re: Re: 98 contour random misfire help
well, why didnt you say so!
Im leaning towards a coilpack issue.
"The CEG Nazi"
www.contour.org
Old 12-14-2005, 02:50 PM
adavis912 adavis912 is offline
Send a message via AIM to adavis912
What type of wires and spark plugs are you using?
1999 Ford Contour 2.5v6 se sport. Thinking about getting 3.0 engine in.
Old 12-15-2005, 08:16 AM
autolite double platnum
