Old 12-13-2005, 04:37 AM
bionictony's Avatar
bionictony bionictony is offline
Send a message via AIM to bionictony
do i need to use sealant on the valve cover gasket?
i replaced my valve cover gasket with a new set from napa and it's been leaking oil around that area now.. not a lot but a little oil wetness around the area. was i supposed to use sealant with the gasket? when i took it off the first time, it seemed like there was sealant along with it.
also, how hard do i screw the 4 screws down? like how much pound torque?
Old 12-13-2005, 06:01 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
Re: do i need to use sealant on the valve cover gasket?
the ft lbs is only like 6 or something like that. they say to put a small dab you know where the hump is for the cam. they say to put a small dab as the base of the hump on both sides
Team Lonely Drivers
Old 12-13-2005, 09:36 AM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
You do not use rtv on rubber gaskets. Sounds like you dont have it tight enough.
Old 12-13-2005, 11:10 AM
sblkcamaro70 sblkcamaro70 is offline
yeah dont use any liquid sealant shit. i dont have any on mine and it is fine. you said there looks like there was some sealant from before? if so make sure you clean alll that off real good otherwise you wont have a tight seal. me i go way more than 6 ft lbs. but if you do dont over tighten and strip out the bolt or stud
Old 12-13-2005, 03:11 PM
bionictony's Avatar
the valve cover has never been off.. this was the first time off.. and it seems like honda used sealant.. i removed it with a razor blade it both sides were smooth. i tightened it pretty tight.
Old 12-13-2005, 05:35 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
http://www.automotiveforums.com/vbul...ght=honda+bond
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 12-13-2005, 06:09 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Mitsubishi silicone works great too.
Old 12-13-2005, 08:22 PM
kris's Avatar
kris kris is offline
Off playing with fire.
Re: Re: do i need to use sealant on the valve cover gasket?
You got it. You only put rtv, or honda bond, whatever, in the weak spots, like the corners where the cam hump is.
Old 12-14-2005, 02:15 AM
allstar323 allstar323 is offline
yeah I got my car in for a tune up and there's this grey sealant looking stuff along with the black valve gasket. I can see it only in some parts (ie. near the dist)
Old 12-14-2005, 05:12 AM
CrxFreak91 CrxFreak91 is offline
yes you can use honda bond it is the only shit you should use on a honda but the valve cover i never use any on just take a 1/4 ratchet and loosely hold it and tighten till you cant turn it that should work
Old 12-14-2005, 04:33 PM
CivicSpoon's Avatar
There is no Spoon
Originally Posted by CrxFreak91
yes you can use honda bond it is the only shit you should use on a honda...
Not true, there are other stuff that are just as good.
Old 12-14-2005, 04:35 PM
AF - Advisor
Re: Re: Re: do i need to use sealant on the valve cover gasket?
such as permatex gray.
with permatex gray, you get twice as much for $4, compared to honda bond which is $15.
