Old 12-13-2005, 12:39 AM
Digitor's Avatar
Digitor Digitor is offline
Send a message via MSN to Digitor
Paint removing with nail polish remover
I know there are a million and one ways to remove paint (the first half being CSC and the remainder oven cleaner) but has anyone tried nail polish remover?
I have no CSC currently and my oven cleaner has dried on the body. I need an alternative!
Please let me know about your experiences, good or bad. Thanks in advance.
Old 12-13-2005, 01:22 AM
sjelic's Avatar
sjelic sjelic is offline
Re: Paint removing with nail polish remover
No way, they are aceton (maybe not caled like that in english) based and that eats an melts plastic like crazy. So forget it.
Sasa Jelic
SCALEMAKERS
Old 12-13-2005, 01:49 AM
Lambo003's Avatar
Lambo003 Lambo003 is offline
Had good luck with Lestoil, Pine-sol or any other degreaser like these.
I've had good luck with Lestoil. Had to strip several pocher kits and due to the size of the models, it was a very cost effective way to strip paint.
Works especially well on resin too!
Chuck
Old 12-13-2005, 06:00 AM
Digitor's Avatar
Re: Re: Paint removing with nail polish remover
You mean acetone?
I'll find some scrap plastic and try it before ruining my masterpiece.
Old 12-13-2005, 06:11 AM
Macdaddy4738 Macdaddy4738 is offline
Send a message via AIM to Macdaddy4738
yea man, acetone will eat that plastic for dinner. Acetone will completely dissolve some threads, nylon comes to mind..
Old 12-13-2005, 07:03 AM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
Yeah, forget trying to strip in acetone- it will destroy the plastic. It would be like trying to strip in laquer thinner.
First thing I would try would be isopropyl alcohol. Safe, cheap, easy to get, and it will more than likely work. It's an excellent solivant -it'll remove automotive paints, and nail polish can't be much tougher than laquers.
PHOTOBUCKET SUCKS
Old 12-13-2005, 07:06 AM
freakray freakray is offline
AF Modelrater
You'll destroy the plastic of the model, just strip paint like it's been recommended here 1000 times.
AF User Guidelines
Old 12-14-2005, 09:10 AM
cyberkid's Avatar
cyberkid cyberkid is offline
hrm.. I actaully USE acetone to strip minor areas using a q-tip and my mouth ... what I do is wet the Q-tip and scrub a little then blow it dry... it can take of paint in small areas without harming too much around it... but needs a lot of care...
In my experience, if you soak a model in acetone: 15 minutes will losen the top layers of paint, 30 will melt detail, 60 will destroy any surface of your model... overnight? hehe... have a look a your new ball of plastic fudge
but actually acetone is good to use for cleaning your tools.. mixing jars, brush tips, and clogged up airbrushes.
anyway.. BE CAREFUL WHEN YOU USE ACETONE!!!!!
As for stipping I use Dot 4 brake fluid, I just chuck the peice to be stripped in a bucket of it and leave it 5-48 hours.. time depends on what type of paint you use and how long it's dried.
Steve
Old 12-16-2005, 07:40 AM
astroracer's Avatar
astroracer astroracer is offline
I use acetone to strip paint... You have to be quick and don't let it sit on the bare plastic. I use a coarse Scotch-Brite pad and oily nail polish remover and do it one panel at a time. Try it on a scrap piece first to get the hang of it but it works fine as long as you don't let it linger... I have done this for years with good results every time...
The alcohol mentioned above is a good degreaser but it will not remove paint. Sorry...
Mark@MAS
Old 12-16-2005, 08:15 AM
MPWR's Avatar
Mark@MAS
It certainly will remove paint. 99% isopropyl will strip laquers and acrylics, at no risk to the underlying plastic. Try it.
PHOTOBUCKET SUCKS
Old 12-16-2005, 08:48 AM
ZoomZoomMX-5's Avatar
While I have no experience using any nail polish remover; there are non-acetone variations of nail polish remover, and I've heard some have had good luck with using it, especially IIRC removing tampo-printed graphics. Not sure about entire paint jobs.
Polly S Easy Lift Off is a good paint remover, don't soak/immerse, just wipe it on and let it do it's work. It's very similar to brake fluid.
91% or 99% alcohol will remove many paints, but there may be some that it's impervious on. It did a fantastic job stripping a pre-painted Polar Lights Ford GT for me. It will remove some fresh lacquers, but the longer they dry the less effective it is. Since it's dirt cheap, that's what I'd try next.
Also heard that Dawn Power Dissolve is a good new product that works for paint stripping. Haven't tried it yet.
My Fotki Album
