Go Back   Automotive Forums Car Chat > Hyundai > Accent | Verna
Old 12-12-2005, 10:42 PM
zerophlux zerophlux is offline
Send a message via AIM to zerophlux
Check engine, misfiring, high idle..
98 Accent, 1.5L SOHC, MT, USA.
First, I did attempt a search. I can't seem to find help that way.
It seems to misfire while accelerating and decelerating, but if I hold it around 3K RPM, it runs fine. This just started happening today. I drove about 2 miles to and from McD's and no problems. Then tonight, I started to go to a friends, and about .75mi into the trip the CEL came on and I noticed the jerking/misfiring. Listening to it at idle, I can hear a sputter. It also seems to want to idle at about 2100rpms. HELP PLEASE!!!
Thanks,
Skylor Williams
Old 12-13-2005, 01:19 PM
PhlatulentPhreddy's Avatar
PhlatulentPhreddy PhlatulentPhreddy is offline
Re: Check engine, misfiring, high idle..
I had some misfire problems and a set of $40 generic cables and some new plugs did the trick. Don't know about idling speed and timing and all that stuff. However, if you haven't swapped out the plugs and/or cables in a while you might want to check that avenue first as it is cheap and can only benefit you. All the best.
Freddy
Old 12-14-2005, 09:58 AM
inatalonIXLR8 inatalonIXLR8 is offline
I second that opinion. Another thing you can do to check for shorting out is take the car somewhere dark at night (no street lights), open the hood and rev the engine through it's rpm range. sparks will be easy to see. You can rev it from under the hood by manipulating the throttle body at the back of the engine.
95 Talon Tsi AWD 5spd
2.4L4G64 6bolt JE8.5EagleTorqueplatedFully ballanced-balanceshaftARP Ferrea1mm 1Ghead ported/polished HKS264/272 fidanzagears turbonetics copy polished GT3076R VbandTial38mm cometic prothane mounts SARD850 stage4 Compclutch+flywheel 3"exh Walbro255 rewired Innovate wideband O2 ForgeBOV Autronic standalone innovative wideband[url=http://img494.imageshack.us/my.php?image=talonandhelicopter5as.jpg]
