Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 12-12-2005, 09:56 PM
jveik jveik is offline
crazy import engines
i have seen all you pepul talk about your import engines making over 1000 horses off of a 4 cylinder and i have a little question. what would u think a chevy 350, or better yet a 454, would do? if i were hypothetically to put similiar levels of boost and nitrous and things of that nature on a gm v-8, what kind of power would i be looking at? i have never heard anything on what these engines are capable of, at power levels that require engine rebuilding after every race lol. i bet if i did something like that to my 350 it wouldnt even last a month lol.
Old 12-13-2005, 06:30 AM
Reed Reed is offline
Send a message via AIM to Reed
well a 1000 hp engine is not going to be a reliable engine for daily driving no matter if it is a 350 or a 2.0. the only ways to make more power are A: to operate more efficiently by reducing the wieght of the reciporcating mass or using a higher comp ratio, etc. B: to burn more fuel by boring or using a larger engine to start with, or supercharging, etc. C: Spin faster. Pushrod V8s (such as your 350) generally cannot rev as high as overhead cam engines (such as almost all smaller import motors) which is one of the reasons that such small motors can make so much power.
Cars are like music.
If it ain't fast it ain't shit.
Old 12-13-2005, 09:17 AM
Re: crazy import engines
yeah i bet it wouldnt even last for 1000 miles, the smallblock only revs up to maybe 6 or 7 k rpm too
Old 12-13-2005, 12:19 PM
Schister66's Avatar
Schister66 Schister66 is offline
AF -Advisor
Send a message via AIM to Schister66 Send a message via MSN to Schister66
you can make almost anything fast....4 cylinders are good for boost tho because of how high they can rev and still make power.....there are many V8s that make power into the 1000's......i prefer the 4 cylinder + boost method.......
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR
Old 12-13-2005, 02:18 PM
Hit_N_Run-player Hit_N_Run-player is offline
Send a message via AIM to Hit_N_Run-player
I6+boost=the win. look at the supras dominating
1988 conquest TSI
-Lots of mods, finally finished WOOT!!
Horsepower sells cars,
Torque wins races!
Old 12-13-2005, 03:40 PM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
Re: Re: crazy import engines
agreed.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 12-13-2005, 05:40 PM
Black Lotus's Avatar
Black Lotus Black Lotus is offline
You Toyopet guys crack me up, such loyalty!
A Chev V8 is a fine place to start. I'd wager that you'd spend a lot less money to get a 350 Chev to 1,000 HP than a Toyota or whatever. ----------You have a lot more cubic inches on your side----, and a lot more aftermarket support. Unfortunately much of the aftermarket engine support is reletively "low-tech". And finding solid information in magazines like "Hot Rod" on building a maximum effort turbocharged Chevy engine is a pipe dream, as they are still in the retro dark ages.
Old 12-14-2005, 09:07 AM
yeah lol i saw some ad claiming it could make over 1500 horses on a 350 and 2400+ on some huge ass big block, prolly a 572 or bigger lol. it would be cool but nothing is worth 2 miles a gallon, although im sure it would be impossible to drive on a street anyways. the cam prolly makes all the power above 5000 rpm, definately a no-go lol
Old 12-14-2005, 09:40 AM
i would rather have my high output engine weight as little as possible. As Sterling Moss said, "the straights are just the boring bits between the curves." A big block weighs a whole lot compared to a 3 liter and that weight will kill you in the corners.
Old 12-14-2005, 09:42 AM
Schister66's Avatar
AF -Advisor
i dont care....i'm going to stick w/ my (soon-to-be)300whp Integra GSR.....i don't need a rocket....
Old 12-14-2005, 01:06 PM
T66's Avatar
T66 T66 is offline
Agreed, don’t need more than 300 whp. Will still haul some serious as5.
English is not my first Language.
Old 12-14-2005, 01:51 PM
Schister66's Avatar
AF -Advisor
it will be streetable and fun, but at the same time reliable.......and the whole thing isn't going to cost an arm and a leg!!
Old 12-14-2005, 05:57 PM
C'mon, you guys are sounding practical!
What's up with that?
(BTW, I hate going to the gas station too. I've also developed an allergy to broken transaxles also.)
Old 12-14-2005, 06:41 PM
Schister66's Avatar
AF -Advisor
im making a practical car...i have to because i drive my GSR daily and need it to last.....eventually maybe i'll play w/ it and boost the shit out of it!
Old 12-14-2005, 06:47 PM
garret_the_driver garret_the_driver is offline
Send a message via AIM to garret_the_driver Send a message via MSN to garret_the_driver
I've seen Supra's and Skyline's with 1000 hp and being driven daily, a V8 could easily achive this. The only problem is that is would use alot of fuel and be tricky to drive on wet roads.
A daily driver with 300hp is enough for me.
"Does it really matter what you drive? Import or domestic, Inline-4 or V8, just have fun. Because in the end, after all the money you've spent and time you've put into it, driving is what it's all about."
FORUMS SHOULD NOT BE CENTERS FOR FLAME WARS!!!.
