Go Back   Automotive Forums Car Chat > Ford > Econoline
Old 12-12-2005, 09:18 PM
Laura G Laura G is offline
Cooling System...Need Advice
I have a '73 Ford E100 van. I tried to repair a small leak with stop leak, but after two minutes, I had to turn off the engine because of a larger hole that opened up. I flushed the system with water and replaced the radiator. I found a metal like substance in the thermostat housing that wouldn't come out, even when pounding on it, which I think may be the stop leak since I didn't run the engine for 1/2 hour as directed. One parts store told me to spray a solvent (engine degreaser) directly on it and flush it with water before flushing the entire system with radiator flush. Another parts store told me not to use engine degreaser, and that I should try filing it down since it may be metal flash castings. How should I get this stuff out of the housing and what should I do to make sure the stop leak is out of the whole system?
Thanks for any advice you can give...
Old 12-15-2005, 04:50 AM
KimMG KimMG is offline
AF - Advisor
Re: Cooling System...Need Advice
Can you post a picture? Can the thermostat housing be removed from the motor? If yes, then you can use degreaser or solvent on it, just make sure it is clean and rinsed before putting back. If possible take it to the store and see what is stuck on the housing first to determine the best course of action. I would just back flush the entire system to get most of the stop leak out.
Old 12-18-2005, 11:42 AM
ModMech's Avatar
ModMech ModMech is offline
Laura G,
That's my wife's name too!
Anyway, stop leak products will not stick to the inside of hoses or cast metal parts unless there is some leak there as it works on a pressure differential and air (sort of like a blood clot).
If the new thermostat will fit in the housing cleanly, you do not have to worry about what is likely just scale build up in the housing.
