Old 12-12-2005, 08:24 PM
Pizzaguy Pizzaguy is offline
launching?
Sad day for me....i lost to a 2005 ford focus ZX3 with a coldair intake, i need to work on my launches, so i need some advice on how to get the best out of my launches, i have a 92 Stealth R/T (non-turbo) ? i need some advice cause i brought it up to 3000....and dumped the clutch and just spun...and he took off...advice please!
Old 12-12-2005, 08:34 PM
VR43000GT's Avatar
VR43000GT VR43000GT is offline
Send a message via AIM to VR43000GT
Re: launching?
You can get a limited slip differential for your FWD for not a whole lot of money.
Old 12-12-2005, 09:06 PM
Morphius289's Avatar
Morphius289 Morphius289 is offline
Re: launching?
I thought limited-slip differentials were fairly expensive. $400-500 the last time I checked. I'd say just work from the bottom up. Start from a cold start, and then work the rpms up while fiddling with the clutch. You'll definitely find the right rpm's that way.
Black 1997 3000GT
Originally Posted by Igovert500
[01:05] Igovert500: scrwe his method
[01:05] Igovert500: too much crap
[01:06] Igovert500: i just jam a garden hose in there
[01:06] Igovert500: and put it on high flow
[01:06] Igovert500: go the opposite direction too
[01:06] Igovert500: so it clears out more shit
18 and out of debt - member #1
Old 12-13-2005, 02:24 AM
quackmandude quackmandude is offline
Re: launching?
well, i gotta 94 3kgt, i usually launch at about 3, a little under. But remember not to slam the gas when you let off the clutch, just leave the gas the way it is until it catches. Theres 2 things that help out alot. For one, the least burn out u do, the better, but a little 'er' is good, that way u dont under do it and bog out. also, u want your car to catch where your torque is at its peak. dont know that stats on that so soemone can help me out there to. but tahts about it, dump the clutch, but dont slam it, just take it easy and ull be fine. also make sure that your tires are good. limited slip diffs. are pretty dam expensive, well it depends who u r. but if ur a good enough driver, u dont need one, bottom line. practice your launches and race him again. your car should blow by him. let me no what happens, peace.
'94 3kgt SL
-ebay intake (why not)
-2 1/2 inch straight pipe exaust, custom y downpipe
-Ignition mods
-dual magnaflow exaust
-going TT (wish me luck)
black book
-'95 mustang v6 (modded) /////
-'00 neon (modded/non-turbo) ///
-'04 eclipse GT
-'05 eclipse GT (modded)
-'97 Prelude vtec (modded)
-CRX (modded)
-Mazda Miata mx5 //
Old 12-13-2005, 11:47 AM
Hotshot8792 Hotshot8792 is offline
your probably going to attempt to laugh at me since i drive any auto.
Anyways, when launching the FWD, you were right around the correct rpm level. Just kind of rev the rpms back and forth between 2500 and 3000 rpms, and right when your go, let the clutch go enough for it catch some, and then dump it. Can't say that i've mastered it or anything as it takes some practice to do. You want it to catch some so you dont spin before dumping it but you dont want it to catch too long before dumping it or it'll slow you down.
Daily Driver: 2004 Jeep Grand Cherokee Special Edition
1994 Mitsubishi 3000GT SL-TT Automatic - Black
3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods
1994 Mitsubishi 3000GT VR-4 - Black
Intake & Boost Controller so far
2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods
