Old 12-12-2005, 08:10 PM
kdiddy8 kdiddy8 is offline
93 3000 vr4 question
On my 93 vr4, my ECS button, does not work? is there a fuse you can replace or something? When i crank the car, it lights up on the dash in the bottom left corner tour and sport, but when i press the ecs button, nothing happens? What could cause this, and what can you do to fix it? Second of all, the clutch is slipping after 115000, miles. If i buy the stock replacement will that be ok. I do not race, but i do get down on it every once in a while? Stock from mitsubishi clutch kit with clutch kit bearing was 283. I can get it put in for about 350.
Old 12-12-2005, 08:20 PM
VR43000GT's Avatar
VR43000GT VR43000GT is offline
Send a message via AIM to VR43000GT
Re: 93 3000 vr4 question
The ECS went out on my 3000gt a few times. After a while I realized that every time it happend it was raining outside or I went through a car wash and therefore my car was wet. Every time it dries off it works agian and stops blinking. However I do believe there is aa fuse for it, check your fuse box and there should be labels on the outside which tell which fuses go where, I would find that fuse and check it.
Old 12-12-2005, 08:21 PM
VR43000GT's Avatar
The ECS went out on my 3000gt a few times. After a while I realized that every time it happend it was raining outside or I went through a car wash and therefore my car was wet. Every time it dries off it works agian and stops blinking. However I do believe there is a fuse for it, check your fuse box and there should be labels on the outside which tell which fuses go where, I would find that fuse and check it.
Old 12-12-2005, 08:26 PM
VR43000GT's Avatar
sorry, accidently hit "post reply" twice
Old 12-12-2005, 09:00 PM
Do you know what fuse it is? i dont see it on the box
Old 12-13-2005, 04:19 PM
VR43000GT's Avatar
I made a mistake, I saw the ECI fuse... it was a while ago that I had looked in my fuse box
