Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 12-12-2005, 07:12 PM
DocBob1497 DocBob1497 is offline
Send a message via Yahoo to DocBob1497
Keyless Programming 98 GP GTP
have a 98 GTP that came with no Key fob...I got one but it is from a Grand Am....can I program it and how???
Old 12-13-2005, 09:16 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Keyless Programming 98 GP GTP
Try the procedure below. If it doesn't work, then you'll need a remote for a Grand Prix. The GM part numbers are different but it would not hurt to give it a try. Good luck!
Programming remotes for a 1998 Pontiac Grand Prix.
1 Get in car and close all doors.
2 Pull the “mall pgm” fuse.
3 Insert key and turn ignition to ACCESSORY. (back 1)
a. Listen for bell(s).
b. Turn ignition off and quickly back to ACCESSORY.
4 Open and close door.
a. Should hear 1 bell to confirm diagnostic mode.
5 Press and hold both the lock and unlock buttons on the RKE transmitter.
a. Hold buttons for approx. 15 seconds.
b. Bell should chime after 7 seconds, continue to hold for second bell.
6 Repeat step 5 for each transmitter. (max 4) (1 bell after 1st transmitter.)
7 Turn ignition off.
8 Replace “mall pgm” fuse.
9 Open Doors.
10 Test transmitters
NOTE: Have all of your remotes on hand when starting this process. Resetting one will cause all others to not function. You must reset all devices at the same time.
Timeslip 08/12/06
AF Community Guidelines
Old 12-13-2005, 06:35 PM
jimmyv-21's Avatar
jimmyv-21 jimmyv-21 is offline
send me the #'s on the back of your remote and i can tell you if they are right
Old 12-13-2005, 09:27 PM
Re: Re: Keyless Programming 98 GP GTP
The numbers on the back are as fallows:
GM/LEAR 25695955
FCC ID: KOBLEAR1XT
CANADA:3521 102 1718
I know it is a stupid question but I am cheap....Please let me know.
Old 12-13-2005, 09:29 PM
PS...what is the part number I should be looking for???
Old 12-13-2005, 10:05 PM
jimmyv-21's Avatar
the gm # is the most important. the one you have will not work on the gp's. i got mine on ebay new for under 10 bucks and programmed it myself using the method above. the best way to check is to email gmpartsdirect with your vin or call the pontiac deal with your vin and either can verify what remote you need. here is one i found on ebay:
http://cgi.ebay.com/ebaymotors/KEYLE...spagenameZWDVW
GM : 10246215
CANADA: 218 101 487
MODEL/ FCC ID : ABO0204T
Old 12-14-2005, 10:50 PM
Onblsht's Avatar
Onblsht Onblsht is offline
Authorized Vendor
Yes, has to be the 10246215 remote.
Replacement keyless entry remotes available here - up to 90% off -
All makes/models from Acura-Volvo, 1988-present -
http://www.OriginalKeyless.com
Old 10-13-2007, 01:43 PM
robtheogre robtheogre is offline
thank you BNaylor for those instructions it worked like a charm (like the 4th time) on my 98 gtp you just saved me $44
Closed Thread
