Go Back   Automotive Forums Car Chat > Ford > Probe
Old 12-12-2005, 06:10 PM
riddem driven riddem driven is offline
Unhappy clutch does not come back up
i have a 94 ford probe that was driving well but then one day the clutch when i pressed it the clutch would not come back up unless i pull it up with the back of my foot and it some times feel like i'm not getting any preasure
Old 12-12-2005, 11:33 PM
spdmon3k's Avatar
spdmon3k spdmon3k is offline
Re: clutch does not come back up
check the master cylender to see if it has ne thing in it, it can either be that or the slave cylender.
L IS FOR LOVE
Old 12-16-2005, 07:52 PM
Re: Re: clutch does not come back up
i changed the slave cylinder and it got worst
Old 12-17-2005, 01:28 AM
KimMG KimMG is offline
AF - Advisor
You may still have air in the hydraulic line or a bad clutch master cylinder. Check to see if the return spring is connected properly on the pedal. Are you losing fluid? Is the slave cylinder moving the clutch fork?
Old 12-23-2005, 01:56 PM
JimR's Avatar
JimR JimR is offline
i would bleed the clutch. i would also check the brake fluid line to the clutch master cyl and slave for leaks.
i would check that the fork is still on the spring clip inside the trans bellhousing.
does you clutch slip when fully engaged? if it does then you need a new pressure plate/clutch.
