Old 12-12-2005, 05:28 PM
bigd1180 bigd1180 is offline
2001 Silverado Pitman arm ???
I have a 2001 4x4 with 66,000 miles on it. Last month or so I noticed the truck was pulling to the left so i rotated the tires and that didnt work. Well to make a long story short I decided to jack up the left side and check the hub and ball joints and such. What I found is that the pitman and idler arm are worn out!!!!! Here is my question is there a way to get the pitman arm off without a special puller??? In order for me to order the parts i need i have to remove the pitman to see if it is a 3 or 4 spline? So the truck will sit and snowmobile season is right around the corner. Any ideas to make this easyer would be great. You think when i had the front end iligned a few months ago they would have found that. Are these parts that faulty on chevs? My first chev I like it but I got over 110,000 miles on my ford before i had to touch the front end(BALL JOINTS) Thanks in advance
Old 12-12-2005, 05:55 PM
jumpingjack66's Avatar
jumpingjack66 jumpingjack66 is offline
Send a message via Yahoo to jumpingjack66
Re: 2001 Silverado Pitman arm ???
unbolt it and take the assembly to a shop with a press and they will press the part off...jj
2000 Silverado Victory Red, standard cab, short bed, short wheelbase, 4X4, 4.8L, 5 speed, 4:10 locking rear diff, K&n FIPK, Ryno lined all the way over bed rail, heavy half suspension,factory skid plates,Fog lights, BFG 285/75/16 A/T's, dashmat, Stealth Radar.
lots of special options some installed by me!
1980 Suzuki GS1100E Super fast
Old 12-15-2005, 11:15 AM
Well I changed both. I pulled out the gearbox because there is no room to get the pitman off anyway. But now i have the airbag light staying on so i guess it is off to the dealer to see whats up with that. If anyone has any ideas what it could be that would be cool Thanks
Old 11-13-2006, 02:46 PM
walleyedave walleyedave is offline
I did the same and now my airbag light comes on. What did you do to fix it???
Old 11-13-2006, 05:06 PM
bigbadram51 bigbadram51 is offline
Yeah, the pitman/idler arm has always been one of the major problems in GM IFS. That and tie rod ends. Luckily for me, with my cognito suspension lift, they address these problems, with an extra support on the idler arm and heim'd tie rod ends, way stronger.
2004 Silverado Half-Ton Crew
7-9" Cognito Lift (set at 8" right now) Betts 7" rear springs w/factory block
3" PA Body Lift
Yukon 4.88's with Auburn LSD
Xentec 6500k HID lows, Silverstar Ultra brights
Wade in channel window vents
Covermaster Top
Flowmaster 40 series, dual outs
Nelson 89/91 HOT TUNE
20" MB Gunner 6's, 37" Toyo Open Country MT's
Eclipse AVN6600 w/sirius and IPOD controllers
Code Alarm w/ Remote Start
Old 11-13-2006, 05:25 PM
What did you do to fix the light??? I got the same problem!
Thanks Dave
