Old 12-12-2005, 04:56 PM
electronicsnerd electronicsnerd is offline
d16a1 head on a D15B2 block
Does the DOHC D16A1 head bolt up with the D15B2 block. The car in question is a 1991 Honda Civic hatchback with the 1.5 Dual Point motor.
Has anyone tried this head swap?
Old 12-12-2005, 08:31 PM
livinincalifornia livinincalifornia is offline
Send a message via AIM to livinincalifornia
Re: d16a1 head on a D15B2 block
D series is NOT dohc. B series is..the D16 A1 head will bolt to the D15 block yes..d series are all compatible but you need to convert to MPFI because only the B2 uses it (although technically you could use it and bolt the DPFI distributor on and run with that, but you'd gain nothing)
Old 12-12-2005, 08:33 PM
arodg25's Avatar
arodg25 arodg25 is offline
the d16a1 IS a dohc out of a 88-89 integra and DOES NOT bolt on to the b2 block.
Old 12-12-2005, 08:39 PM
arodg25's Avatar
Re: Re: d16a1 head on a D15B2 block
I just read your post again. You have no idea what your talking about. please be sure of information you give out hear. what if that guy read your post and bought the d16a1 head before someone could correct you? he'd be out the money and tell people that the automotiveforums give wrong info.
Old 12-12-2005, 08:40 PM
ah sorry, ZC, I forgot the A1, I apologize. The A6 would work.
Old 12-12-2005, 08:41 PM
THe first gen integra engine (d16a1) this is a d series engine and it is dohc http://en.wikipedia.org/wiki/Acura_Integra
The second gen integras got the b series engines.
My question is does the 1st gen dohc integra head (d series) bolt onto my d15b2 block, does everything line up?
I was already planning on the MPFI conversion
Old 12-12-2005, 08:43 PM
wouldn't say I don't know anything, besides that I forgot the A1 is DOHC? This is probably the first time I've made a mistake on here, thanks for busting my nuts.
Old 12-12-2005, 09:18 PM
If the head wont bolt to the d15b2 block what would it bolt to?
Would it be possible to use the d16a1 head on the 1.6 SOHC non VTEC Block (D16A6).
I was hoping that I could use something d series based so that I can keep the motor mounts I have, and there are alot of these engines at the local salvage yard.
Old 12-12-2005, 09:54 PM
arodg25's Avatar
dohc heads will only bolt to dohc blocks and in the d series, i think your only options are the d16a1 and the zc, however im not sure if it will even bolt to the zc block. and it will be hard to find a zc block without the zc head. oh and im pretty sure the d16a1 mounts dont match up with the 88-91 civic/crx anyway. so where that leaves you i dont know, but if you want more power and stock motormount placement just get d16z6 or y8 head and do a minime or something. there still sohc but vtec and will bolt to the b2 block.
Old 12-12-2005, 11:58 PM
It seems the coolant and oil passages do not line up correctly. Some of the members over at http://www.d-series.org/ have tried it with mixed results. The swap requires some machining to be done to work correctly. Seems like the swap would be more trouble than it is worth. Has anyone on here tried this swap?
-Rob
Old 12-13-2005, 08:43 PM
arodg25's Avatar
im pretty sure the head studs dont even match up.
Old 12-14-2005, 06:25 AM
Hybrid1990crx's Avatar
Re: Re: Re: d16a1 head on a D15B2 block
-Rob
hey man can you post up some links to the dudes that tried it before? im not calling you out or saying its impossible, cause i've heard of people doing it before, but it requires a lot of machine work or something. I just want to read about it.
Old 12-15-2005, 11:01 PM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
check www.d-series.org
theres a few guys on there who have done this and the ZC head swap SUCCESSFULLY
Old 12-17-2005, 06:36 PM
honda_luvr_2000 honda_luvr_2000 is offline
i know for a fact from personal "attempts" that the dohc d-series head will NOT bolt to any sohc d-series block. reasons are: that the oil passages do no line up to the point of two passages are exposed to open air; and the head bolt holes do NOT line up either.
the reason i "tried" was simple i had a d16a1 motor i bought for the pistons and rods. i had a d16y8 head for doing a mini. i thought of using the d16a1 complete block to save time and $$$, set the y8 head on the a1 block, and presto it was a no-go. since u can put a z6 and y8 head on ANY sohc nonvtec d-series block, then that solves that the dohc d-series heads have to be on dohc d-series blocks. there r three dohc d-series engines that i know of. d16a1, d16a8, d16a9. dohc zc is the a8 & a9.
Originally Posted by Greenblurr93
ahh i see said the blind man to his deaf wife, as he pissed into the wind, its all coming back to me now.
Old 12-17-2005, 07:43 PM
1PhatCX's Avatar
explain how people on d-series.org are using this setup then? explain how i bolted a DOHC ZC head onto my d15b2 block?
