Go Back   Automotive Forums Car Chat > Toyota > Supra > Maintenance
Maintenance Have questions? Find answers. Help out fellow Supra owners.
Old 12-12-2005, 04:02 PM
97cavalier's Avatar
97cavalier 97cavalier is offline
fuel filter
I have a 87 supra turbo it is a 5 speed stick and where is the fuel filter on this? and how hard is it to change?
Old 12-12-2005, 08:09 PM
projectsupramk3's Avatar
projectsupramk3 projectsupramk3 is offline
Send a message via AIM to projectsupramk3
Re: fuel filter
It's above the gas tank, towards the diff, it is also a PITA to change. Toyota put it there because it is not supposed to be changed on a regular basis like the other filters. Unless you dumped sand into the gas tank it is probably fine. If you do want to change it you need either some skinny hands or you need to drop the tank. Only two bolts hold it on IIRC, but the hoses can be a pain also.
Old 12-12-2005, 08:16 PM
97cavalier's Avatar
Re: Re: fuel filter
i have 122,000 miles and it is original filter, do you think it needs to be changed?
Old 12-12-2005, 09:21 PM
TcmaBoy's Avatar
TcmaBoy TcmaBoy is offline
AF - Advisor
Re: fuel filter
At 122,000 it is time. Be sure to use line wrenches. If you use regular box wrenches you will strip the lines.
Don't you SAS me boy.
Please wheel responsibly.
http://www.treadlightly.org/
Old 12-12-2005, 09:43 PM
97cavalier's Avatar
Re: Re: fuel filter
Ok thanx for all the help. Is it hard to drop that tank?
Old 12-12-2005, 11:29 PM
TcmaBoy's Avatar
AF - Advisor
Re: fuel filter
It is not too hard if you have a helper and a Haynes manual. Drain it. There is a plug under the tank. It is a square plug designed to be removed with a 3/8 ratchet. There are 2 straps that hold the tank up. There are 2 bolts at the front of the tank that hold them on. Undo all the electrical connections. There is a trim piece in the gas door that has to be removed to allow the filler neck to drop out. Be careful when dropping the tank. You have to lower it part way then disconnect the fuel lines. Be careful you don't damage the filler neck.
Old 12-13-2005, 05:11 PM
Yellow 13's Avatar
Yellow 13 Yellow 13 is offline
Send a message via AIM to Yellow 13
Re: fuel filter
I have 260,000 miles on my original fuel filter and havent gotten any problems yet.
