Old 12-12-2005, 03:15 PM
Andrew1975 Andrew1975 is offline
Help! changed heater core, now won't turn over
Ok...had a friend of the family change my heater core at his shop, now the truck won't turn over to start. He said that he can hear the fuel pump when he turns the key, but no turn over. I wasn't there when he changed it out. Anybody have any ideas on what might cause this? It's a '96 LS 4WD. Any help would be greatly appreciated. Thanks.
Old 12-12-2005, 03:33 PM
cleanshavenrsx cleanshavenrsx is offline
Send a message via AIM to cleanshavenrsx Send a message via MSN to cleanshavenrsx
Re: Help! changed heater core, now won't turn over
is the starter cranking? if not then its probably a problem with the ignition switch because the heatercore is behind the dash board
Old 12-12-2005, 09:12 PM
srbianats srbianats is offline
Did anything come loose. Don't the heater core hoses come through the firewall right next to the distributor. Maybe the wire from the coil to the distributor came loose. I got a 98 and figure your distributor should be in the same place. Also, maybe the distributor got wet and you have moisture in the cap.
98 Blazer LS 4x4 (STOCK)
.ǝɹǝɥʇ noʎ ʇǝb 11ıʍ pɐoɹ ʎuɐ 'buıob ǝɹɐ noʎ ǝɹǝɥʍ ʍouʞ ʇ,uop noʎ ɟı
Old 12-13-2005, 01:49 AM
Rmbodie's Avatar
Rmbodie Rmbodie is offline
Wont turn over as in NO reehh , reeeh , reeh . No clicks . Is it posible that the battery was not connected first and the interior lights ran the battery down . It happened to me . Not familiar with the replacement on blazers ,But on a jeep you have to remove the whole dash (door to door). Loosening the steering column in the process . Grounds and harnesses could be effected if this was the same R&R . Rob
Old 12-13-2005, 12:28 PM
Cailen Cailen is offline
Are all electrical harnesses connected? One time I left that little engine bay light harness unplugged and my truck wouldn't start. Took me like 5 minutes of staring to figure it out..
Are the dash lights coming on? Do you know that you have spark? srbianats may be right in suggesting you could have gotten some moisture in your distributor cap.
Originally Posted by blazee
If you would pull your f ing head out of your f ing ass and read the f ing thread, you will see that I posted the most common f ing cause in f ing post # 4 and Swalt followed it up with more f ing details in f ing post # 8. From what we f ing posted you should be able to f ing realize that if you have two new f ing tires on the f ing front and two raggedy ass f ing tires on the f ing back... that is probably causing your f ing bang. Try not to be such a tool. Can you do that, Thank you. f head!
