Go Back   Automotive Forums Car Chat > Buick > Riviera
Old 12-12-2005, 02:46 PM
jas_stang jas_stang is offline
95 riviera p0108 map sensor circuit high input
service engine soon light came on, scanned and got code p0108 manifold absolute pressure/barometric pressure sensor circuit input high. Don't know what to check from here, car runs fine, no noticeable difference.
Old 12-12-2005, 04:04 PM
maxwedge maxwedge is offline
A990 racer
Re: 95 riviera p0108 map sensor circuit high input
The map sensor vacuum hose may be cracked or blocked, connector loose or the map bad. Try and do a full scan see what it reads as a baro sensor, with key off should read the baro readings for your area.
Old 12-19-2005, 12:46 PM
thanks for the help, removed sensor from intake,found seal broke,sensor came out in 2 pieces. Replaced sensor and pcv, solved problem
