Go Back   Automotive Forums Car Chat > Honda > Integra
Old 12-12-2005, 02:16 PM
integra123 integra123 is offline
Unhappy rpm problem
i have been having a problem with my rpms. they jump from 1 to 3000 and it only stops when the car is completly warmed up. i noticed to that when it is jumping my heat doesnt work. and once the rpms stop jumping everything is fine and everything works. does anyone know whats wrong??
Old 12-13-2005, 04:26 PM
WReX WReX is offline
Re: rpm problem
is this at idle?
26 PSI anyone?
Old 12-13-2005, 08:14 PM
Re: Re: rpm problem
Originally Posted by WReX
is this at idle?
yes its at idle.
Old 12-13-2005, 08:21 PM
Re: rpm problem
it might be a mass air flow or O2 sensor problem
26 PSI anyone?
Old 12-14-2005, 02:03 PM
Re: Re: rpm problem
i noticed that if i start the car a dont touch anything it doesnt happen. but if i touch the gas pedal it starts up immediatly. when i turn the car off and back on its fine.
Old 12-15-2005, 02:23 AM
hmm...could be an ecu thing..?
i'd have somebody check over the sensors i mentioned earlier, i had a friend of a friend who thought it would be a good idea to run with out a mass air on his b16 and his car had the same characteristics as yours...and lets say we don't let him near our cars anymore
26 PSI anyone?
Old 12-21-2005, 02:53 PM
tardster tardster is offline
I have a question, today I was driving down the road at a steady 30 mph when all of the sudden my rpm's dropped 1000 rpm's for just a second then it went back to normal. This happened 3 times, but once the car warmed up it seems to be fine now. Could it be from one of the sensors you mentioned? Thanks in advance...
Old 12-22-2005, 12:53 AM
Re: rpm problem
did you get any CELs?
26 PSI anyone?
Old 12-22-2005, 05:36 AM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
the should naturally rev high when the engine is cold, until the o2 sensor gets hot. if your idle is jumping during this process, then, maybe you should give your iacv a look.
and it only stops when the car is completly warmed up. i noticed to that when it is jumping my heat doesnt work and once the rpms stop jumping everything is fine and everything works. does anyone know whats wrong??
while its jumping and cold, your not going to get heat. if you turn the heat on while the engine is cold, your just going to make it longer for it to warm up.
hondas dont use mass air flow sensors they use manifold absolute pressure sensors. if there is a problem in the o2 sensor, a cel will be thrown.
as stated above, check iacv, map, tps, and vac leaks. really though, if its fine when the engine is warm, your ok. just check up on those other components.
as stated before, there are no mass air flow sensors on hondas. check the map sensor though the map sensor is minimally used during idle. it is when the engine is under a load that it really starts doing its job.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 12-22-2005, 01:56 PM
sorry about the incorrect terms but thank you for correcting them didn't mean to mislead anyone
26 PSI anyone?
