Stealth SOHC 5 spd vs 3000gt auto
There is a guy at my school with a 1992 (appx) stealth SOHC with a 5 speed. I have a DOHC 1991 3000gt with only 36k on the motor, who would take the win?
Re: Stealth SOHC 5 spd vs 3000gt auto
Is your 3000GT a VR4? Either way, it's SOHC vs DOHC. I give the win to you due to ammount of cams.
Black 1997 3000GT ![]() Quote:
who's got the mods? and what mods?
I got a SOHC, when my transmission works right... I take most DOHCs (stock)... I don't think there's one here other than the VR4's that will take me... (most only have an intake)...
1991 Eagle Talon TSI - Broken Head removed, block broken, trans in hatch ![]() 1991 Eagle Talon TSI AWD- in pieces 3" exhaust, rebuilt bottom end Project: Assemble the Eagle is underway... and now with AWD 2003 Lancer Evo 1630hp/1593ft lb tq |
Re: Re: Stealth SOHC 5 spd vs 3000gt auto
that DOHC gives u ~60hp more... even with a less efficient transmission... you should have him... especially if u guys are both stock... he may pull a little off the line... b/c he's hauling around less weight... but only ~200lbs less... if either one of you has a heavy ass system in the car, drop it out first... (I used to do it all the time... quick connect terminals... and shit... I'd have my buddy with an Aveo 5-door (wagon) follow me to the races... I'd be in 2nd race... that'd give me enough time to slip the box outta the back of my car into his... and whip some ass... any extra weight like that will slow u down...
but DOHC definitely has more oomph if u r both stock (for that matter if each of u had the same mods, the DOHC would still benefit more than the SOHC)... the intake on the DOHC allows it to breathe easier... and the extra camshaft gives that extra NA oomph... so I think u got him... not even counting any gain from the K&N
he would probably get you off the line because our autos naturally aspirated are a little sluggish off the line, however, if he can't launch, that factor falls out of place. After ya'll get going, you should be able to walk him. We had a race like that 2 years ago here in town. The SOHC got off the line, and the auto caught him and was passing him by around 1/8th a mile. Go from a highway roll . . . your gearing will be far superior to his (short gears at high speeds plus only a 6K redline vs your 7K), plus the better heads and higher compression ratio will give you a huge advantage.
Daily Driver: 2004 Jeep Grand Cherokee Special Edition 1994 Mitsubishi 3000GT SL-TT Automatic - Black 3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods 1994 Mitsubishi 3000GT VR-4 - Black Intake & Boost Controller so far 2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods |
As for the SOHC MTX v DOHC ATX, I havent actually ran any in a 1/4 mile race but have witnessed several DOHC NA ATX runs. My stock time is faster than most of there modded times. A roll race the DOHC ATX gets the advantage because its already out of its sluggish first gear. So it depends on how the race goes down and if the SOHC driver can shift on who would win.
VR4s never came in autos... other than that I think you should be able to take him... I'm not exactly sure on how you would go about launching an auto properly (hold down the brakes and rev????) but if you take him from a roll, I say that that's all you mang...
Georgey on the subject of midget beastiality pornos Quote:
R.I.P Andy, you will be missed by all. |
Re: Re: Re: Stealth SOHC 5 spd vs 3000gt auto
Damn single turbo's are hot. Good luck over the holidays.
Re: Re: Re: Re: Stealth SOHC 5 spd vs 3000gt auto
And from a dead stop.... I have cut 2.2 and a few 2.19 60's on street tires. I can launch it like a mo fo. And I shift like no ones business. As for your mods, the intake adds maybe a max of 1 hp, the catback a max of 5hp, the flywheel doesnt really add any hp, and of course neither does the clutch. Heres my mods taken from my sig on 3si ACT Maxx Xtreme clutch-4.5" open element filter-removed resonator-DOHC TB-gutted precats-3sx DP-2.5" test pipe-TT catback-removed EGR-IPO 8.5mm MSD Superconductors-NGK plugs-3kgtmotorsports STS-solid shift bushings I plan on a few more mods but am staying away from turboing it. That was my initial plans but all the fab work needed made me shy away. When I want boost I'll buy me a VR4.
[quote=Stealthee]
As for your mods, the intake adds maybe a max of 1 hp, the catback a max of 5hp, the flywheel doesnt really add any hp, and of course neither does the clutch. [quote] It won't make any more hp at the crank, but if its a lightweight flywheel it will reduce rotational mass and reduce hp loss to the wheels. The same way AWD and RWD cars loose more hp from the crank to the wheels. Still not a big gain in horsepower.
I have no car
yea back to that single turbo, GOOD LUCK WITH THAT. lol no foreals i wanna do that to mine, but i dunno, i get so many diferent opinions. I no its better to do the TT conversion, BUT WHY!!! when everyones doing it, u no? some said one manifold was bad, but some said it was alright, some suggested i do it at the down pipe where they meet, lol, that'll be interesting wont it. well good luck.
'94 3kgt SL -ebay intake (why not) -2 1/2 inch straight pipe exaust, custom y downpipe -Ignition mods -dual magnaflow exaust -going TT (wish me luck) black book -'95 mustang v6 (modded) ///// -'00 neon (modded/non-turbo) /// -'04 eclipse GT -'05 eclipse GT (modded) -'97 Prelude vtec (modded) -CRX (modded) -Mazda Miata mx5 // |
Re: Re: Re: Re: Re: Stealth SOHC 5 spd vs 3000gt auto
Well, as far as the flywheel is concerned... dropping almost 20-30 lbs of rotating mass... that does make the car a lot quicker... to my understanding... it does add hp, or at least frees it up and makes it available alot quicker... and when my car's together... I can shift it like no other... but for now, I'll be taking it easy...
