Trust bearing or Starter motor
I had a 2nd opinon on my CV with regards to the Trust bearings gone. I had another mechanic look at my CV without telling him about what the first mechanic had found. The 2nd mechanic said that the starter is not fully retracting after car is starting and that is what is causing the noise that I am hearing. The 2nd mechanic said that the starter is hitting the fylwheel casuing the rattle noise. Question, would a worn Thust bearing casue the fylwheel to backin to the the starter ? Any opinion would be approcated.
If your thrust bearing is that bad then you should be able to move the crank. Usually you have burrs on the teeth of the flywheel causing this problem
1967 cougar 390 FE in progress 1993 F350 Crew Cab 5.8 111K 1983 Coachman 23ft class C 460 1988 Bronco 351 C6 1964 Galaxie 428 4sp project 1995 Mustang 3.8 Auto 1966 Mustang Fast back Project 1994 Tracer Trio 1.9 1968 F250 Camper Special 390 |
