Old 12-12-2005, 08:34 AM
FormulaForce FormulaForce is offline
Carbon Driveshaft
I ordered a carbon driveshaft because I am still having high-speed vibration problems even with an aluminum driveshaft on my 95 formula. It's not here yet, but I was wondering if anyone else has one and if you noticed any performance differences. I hear that they deliver more rear wheel hp, but I also heard that you lose some driveline torque because it's lighter. Comments?
Old 12-12-2005, 05:16 PM
Matt365's Avatar
Matt365 Matt365 is offline
Send a message via AIM to Matt365
Re: Carbon Driveshaft
you sure your drive shaft was balanced? the drive shaft shouldnt just cause vibrations like that. No advice to you on the drive shaft. Also, is the vibration limited to a set speed range?
Old 12-12-2005, 08:45 PM
88camaroproject's Avatar
88camaroproject 88camaroproject is offline
Send a message via AIM to 88camaroproject
woah carbon driveshaft... where you order from? how much? oh and how much lighter then a aluminum is it?
87 firebird formula ws6
(currently has a old 78 305 with the following upgrades,
including lots of miles and stock heads and internals....oops)
crane cam cam specs
performance valve springs and retainers, flowtech headers, 255 lph fuel pump,
holley 600cfm carb, weiand single plane manifold, a healty diet.
14.90 1/4 mile....just wait for the 406 to be finished
MY VIDEOS
MY PICTURES
-Tom
Old 12-12-2005, 08:53 PM
The aluminum shaft was a new GM part that has balancing weights on it. The vibration happens at 85+ mph, i guess thats the "critical speed" of the shaft in my car. I've seen technical bulletins on the problem, in that the transmission output shaft and the differential must be within 1 degree of each other to avoid vibration problems. If the carbon shaft doesn't solve the problem, I'll have to have the output shaft, universal joints, and driveshaft balanced as an assembly. I'm fairly confident that it will fix the problem though. For $700, it better.
Old 12-13-2005, 01:01 AM
importeater38's Avatar
importeater38 importeater38 is offline
Send a message via Yahoo to importeater38
you can get them through Year One. I was looking into one, but im skeptic it will handle the HP when i finally put my 396 stroker in.
93 trans am hurst shifter and zo6 rims. 94 trans am GT. functional ram air hood w/k&n air box, ROH rims, toyo skins, Borla cat back SS, TB bypass, de-screened MAF, BBK underdrive pully, Mieziere electric water pump, spec stage III clutch. '06 Yukon Denali XL, black, loaded. http://www.cardomain.com/ride/711131
Old 12-13-2005, 08:36 AM
I ordered it from Thunder Racing in Louisiana, they were having some kind of anniversary sale. With shipping, it was $768.00
As I remember, the steel shafts are 12 pounds, the aluminum ones are 8 or 9, and the carbon ones are about 6 pounds. As for strength, I've heard some carbon shafts are rated to 800 hp or so. They must be able to handle power, because they are using them on diesel trucks to cut down on vibration. I have another used one I bought to fit my 95 formula, but it's a little too long for 3rd or 4th gens and must have been meant for earlier cars or a drag setup. I'm going to sell it. If anyone wants it let me know, it's in great shape. Otherwise I'm going to ask about $200 + shipping on e-bay for it.
