| Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
power loss
i bought a 2.0 92 dsm for my girlfriend.its an auto.i just put a new engine in and we got the car with a blown engine.its running now but when i give it gas, the engine totally cuts out unless i barely give it gas and then slowly push it further.i can drive it around but it sucks.no power what so ever.i put a new coil pack,power transistor, plugs wires,and a very thorough tune up. any suggestions on how to make it run right? i know quite a bit about dsms but i am stumped
Re: power loss
You know spark is good right? Fuel my friend. Fuel. Check it. Pump, injectors, lines. Sounds to me like you have a clog in the injectors or lines.
1991 GSX 2.3 Stroker |
Re: power loss
Is it turbo or na? could be a boost leak if turbo, or it could be a mas problem.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff. http://www.ratemydsm.com/member/ez1286/?member=ez1286
Re: Re: power loss
Re: power loss
Ive got the same problem on a 93 so be sure and let me know when you find out.
Re: power loss
a damn NA is gonna be slow regardless... 140 to crank... 104-110 to the wheels... and it's an auto...
1991 Eagle Talon TSI - Broken Head removed, block broken, trans in hatch ![]() 1991 Eagle Talon TSI AWD- in pieces 3" exhaust, rebuilt bottom end Project: Assemble the Eagle is underway... and now with AWD 2003 Lancer Evo 1630hp/1593ft lb tq |
Re: power loss
Thread is ALMOST a year old, please don't bring back old threads unless you have something important to add or are the original poster and have an update. Thanks.
