Old 12-11-2005, 10:59 PM
miseryinlife miseryinlife is offline
Exclamation 4dr '01 power window problems wiring/switch?
Got a 4 door 2001 grand am with power window problems...
The master switch (driver's side) works on all the doors, but the switches on the other doors do not work at all. Thought the master switch was bad so replaced it..still the same problem. The chance of the window safety lockout being bad on both is slim.
ANY help would be GREAT!!!
Old 12-12-2005, 01:28 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: 4dr '01 power window problems wiring/switch?
Hello miseryinlife. You could hav probley saved yoiur self some money on the new master swtch. Did you check the fuses and relays?
Other than that you need a light probe to test all the other swithces that dont work, and test the saftey lock out for power(driverside) with the light probe too.
This new of a car shouldnt hav to many problems though, umless the switches get wet regularly.
If everythings getting juice then try some compressed air to blow out debrei, then spray electronic contact cleaner(follow directions[ with the key off ]) into the switchs that dont work and just work them back and forth several times.
If this all fails, you'll hav to bite the bullit and take it to the dealer.
1999 Grand Am SS 3.4 OHV
