easy way to change the oil filter for toyota 4runner 96 - 2002
well it was an option for me to take out the skid plate untill i was fed up ...here is an easy way ...front driverside wheel just turn it to the left al the way look behind it u will see a cover plastic or rubber sheet ..hell i do not know what u cal it anyway it has few clips on it just take them off jentely with a screw driver and then u will see that u have a gap that u could easly snake ur hand and arm to get that filter out ...got it guys ?? well if the filter is tight u may have to do it the skid plate way and you make sure u put it tight enought to make easy for ur self to take it off the nex time ....willl be more than happy to pass more tips about that ...good luck
Re: easy way to change the oil filter for toyota 4runner 96 - 2002
If you do it that way, make sure you take a hose or something and wash off your front differential and engine cover because you've just dumped a half-cup of really dirty oil on them. Fast, but dirty.
That's the way Jiffy Lube does it. I wouldn't suggest putting on the filter less tight that snug plus 3/4 turns as is recommended. It's your engine.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html "What we've got here is a failure to communicate" |
Re: Re: easy way to change the oil filter for toyota 4runner 96 - 2002
