Go Back   Automotive Forums Car Chat > Pontiac > Aztek
Old 12-11-2005, 11:19 PM
mapletek mapletek is offline
Angry aztek rear hatch stuck solid
my 2001 aztek hatch won't open period, not with the button not with the key not with the inside handle. i checked the fuses and they are all fine.
i am not talking about not opening from secondary position but locked stuck jammed or what ever you want to call it.
Old 12-12-2005, 07:45 AM
Chameleon-kat's Avatar
Chameleon-kat Chameleon-kat is offline
Send a message via AIM to Chameleon-kat Send a message via Yahoo to Chameleon-kat
Re: aztek rear hatch stuck solid
Mapletek, If your not hearning anything when you use the fob or inside cabin button, theres a fairly good chance its a BCM issue. Others had found a temp fix by removing the BCM fuse for a count of ten. It is fuse number 28 in the under hood fuse box. Give that a try and see if it helps. Ray
Old 12-12-2005, 03:40 PM
rockgirl0366 rockgirl0366 is offline
Thumbs up Re: Re: aztek rear hatch stuck solid
Oh MY GOD it works!! Thank you Chameleon-Kat. My 2001 Aztek just locked yesterday. I also tried the inside fuse (no luck). After reading your suggestion - I tried #28 in the under hood box, and it WORKED!! Thank you thank you thank you
Old 12-12-2005, 04:52 PM
you right on. it worked and was a lot simpler than my next plan that involved a drill and crow bar.
thankyou
Old 12-13-2005, 08:01 PM
Re: Re: Re: aztek rear hatch stuck solid
Glad it worked for both of you, just don't forget the part I said about 'temp fix' , it may comes back and perhaps the quick thing won't work.
Old 12-14-2005, 08:30 PM
Lightbulb Re: Re: Re: Re: aztek rear hatch stuck solid
true but im a little more aware and prepared.thanks again.
Old 04-29-2006, 10:40 AM
oaguilarm oaguilarm is offline
Send a message via AIM to oaguilarm Send a message via Yahoo to oaguilarm Send a message via Skype™ to oaguilarm
Chameleon-Kat, thankyou so much.
I had the same problem on my 2002 Aztek, the fuse 28 solution worked for me too!!! What might be the cause of the problem on the BCM?..can it be fixed for good?
Regards from Mexico City,
Octavio.
Old 11-30-2011, 07:00 PM
rtguitard rtguitard is offline
my hatch was not working i reset bcm and it did nothing i found conector in wiring harnace on top of spair tire ware their was a dirty contact also if you send 12v to the light blue wire it will open gate.
Old 05-20-2014, 06:49 PM
fxdago fxdago is offline
Thanks a Lot! After 4 days with a rear hatch blocked, your trick works!
