Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 12-11-2005, 09:57 PM
directory's Avatar
directory directory is offline
CEL came on
went out to the parents house tonight. passport drove great. was there for awhile, then went out and started it to let it warm up. no problems yet. was inside for about 20 minutes, came back out and the check engine light was on. the truck sounded like it had a lower idle than usual (don't seem, anyway)
so, being as brave (or stupid) as one can get--i drove it home about 8 miles. no running problems, no idle problems at stoplights or anything. got home, turned it off, then restarted it--no problems. checked gas cap--it seemed tight. checked oil, looks like there is some--may check it later just to be sure.
of course, it's 10pm here and autozone is closed--so i can't check codes. so great, another sleepless night worrying over the truck!
of course--with such a vague discription--i don't expect much, but is there anything else i should be checking? i had the oil changed friday, i'm hoping the yahoos didn't forget something.
1999 passport 3.2l v6 4x4
99 passport 3.2L v6 DOHC auto-trans 4x4 modified IFS 10 bolt front/ dana 44 4.10 rear
SKYWARN
we be clubbin'
--B
Old 12-11-2005, 10:03 PM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: CEL came on
If it is not flashing I wouldn't worry about it.
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 12-11-2005, 10:11 PM
directory's Avatar
Re: CEL came on
is there a seperate low oil light?
also the temp gauge didn't read abnormal (in the usual normal run range that i always see)
ryan--thanks, you are setting my mind at ease....i may get a little sleep now...
SKYWARN
we be clubbin'
--B
Old 12-11-2005, 10:37 PM
Isuzu Guy
Re: CEL came on
typically, if the low oil light comes on it is too late. . .
Since you know about the oil usuage on Isuzu's I'm sure you have ben watching your oil every 1k.
no worries.
-Ryan
Isuzu Moderator
Car Show Tips
Old 12-12-2005, 07:56 AM
abilyk abilyk is offline
Probably just your EGR needs cleaning.
Old 12-12-2005, 10:00 AM
directory's Avatar
Re: CEL came on
i'm hoping...
i got under the hood and had to tighten the oil cap about 1 1/2 turns. then i drove it to work this morning. the light is still on..bummer.
off to autozone later to get the codes read....i'll keep you all posted.
SKYWARN
we be clubbin'
--B
Old 12-12-2005, 04:09 PM
directory's Avatar
Re: CEL came on
went to autozone
p0171 oxygen sensor in bank 1 (or something)
he tried to sell me some lucos fuel cleaner or whatever stuff it is...didn't buy it without checking with you all first--any good? or do i just replace the sensor?
do i have any worries? that was the only code that pulled. i did notice a lower idle--would that cause it?
SKYWARN
we be clubbin'
--B
Old 12-12-2005, 04:13 PM
directory's Avatar
Re: CEL came on
a search of the fourm answered my questions---bad o2 sensor with cause awkward engine idle.
how hard is it to change?
SKYWARN
we be clubbin'
--B
Old 12-12-2005, 04:20 PM
Canucklehead Canucklehead is offline
Send a message via MSN to Canucklehead
Re: Re: CEL came on
Not too bad. It's the driver's side pre-cat sensor. Get an O2 sensor socket (or 22mm wrench) and some PB Blaster.
All you have to do is unplug the old sensor, unscrew the old sensor. Anti-seize the new sensor, screw it into the exhaust and plug it in. Unless you have to soak it with PB to loosen it up it takes about 5 minutes to replace.
2000 VW New Beetle TDI
2007 Honda CR-V
Old 12-12-2005, 04:22 PM
directory's Avatar
Re: Re: Re: CEL came on
outstanding. looks like i'm under teh passport this weekend..but then again i did read in a few posts that the p0171 code could also be caused by a bad IMG...ugh! i guess go cheap first, then dread the major expense...
SKYWARN
we be clubbin'
--B
Old 12-12-2005, 04:31 PM
Isuzu Guy
Re: CEL came on
is your IMG orginal?
-Ryan
Isuzu Moderator
Car Show Tips
Old 12-12-2005, 04:37 PM
directory's Avatar
Re: Re: CEL came on
>sigh<....yes....
i know, i know...it's gonna be the IMG.... how long can i drive on it before major concerns start to appear?
i saw in one post to spray break cleaning fluid along the intake sides and listen for the engine to rev up, does this work?
SKYWARN
we be clubbin'
--B
Old 12-12-2005, 04:39 PM
Re: Re: Re: Re: CEL came on
You can check to see if it is the O2 sensor by swapping the Pre-cat and Post-cat sensors and see if you get a different code (or no code at all). Additionally, as Ryan pointed out it could be a bad IMG since P0171 isn't really an O2 sensor code per se.
2007 Honda CR-V
Old 12-12-2005, 04:56 PM
directory's Avatar
Re: CEL came on
"since P0171 isn't really an O2 sensor code per se."
yeah, i'm starting to gather that as i dig deeper in other posts....
SKYWARN
we be clubbin'
--B
Old 12-12-2005, 04:57 PM
directory's Avatar
Re: CEL came on
any recommendations for a new IMG? any tough made gaskets out there? heavy duty or what not...
how about o2 sensors, in case that is the problem...just regular bosch ones?
SKYWARN
we be clubbin'
--B
