Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 12-11-2005, 09:51 PM
RavagePenguin's Avatar
RavagePenguin RavagePenguin is offline
Send a message via AIM to RavagePenguin Send a message via MSN to RavagePenguin Send a message via Yahoo to RavagePenguin
Oil filter housing problem
A while back I split an oil filter housing in half on my 92 Eclipse. Now I found a new part but it says its built to have an external oil cooler. The one stock has an internal cooler. Now is there a way I can just have this housing work with the internel one because I can't really afford to put $190 cooler on the car. If not would I be able to hold out in the Arizona)winter till I can get some more money to put it on. Cause its in 60's here and I'm wondering if I could just settle with that.
Old 12-11-2005, 11:17 PM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
Re: Oil filter housing problem
Sixty in winter? I hate you (i live in chicago it's fucking cold) The 90 eclipses had the external oil cooler maybe you could find one for cheap that way.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 12-11-2005, 11:57 PM
Re: Re: Oil filter housing problem
Thats the problem I'm having a hard time finding a junkyard that has a DSM without all the good parts stripped away.
Old 12-12-2005, 05:36 PM
ez1286's Avatar
Try ebay or http://www.mitsubishigraveyard.com/
Old 12-12-2005, 05:44 PM
Originally Posted by ez1286
Tried ebay but I'ill try the website you posted
Old 12-12-2005, 10:42 PM
So will the external mount set-up to allow me to use the water set-up till I can get an oil cooler for it
Old 12-12-2005, 10:44 PM
So will the external mount set-up to allow me to use the water set-up till I can get an oil cooler for it. Also will I have to block the external oil cooler line to keep the oil from spraying out the bottom. Its important I get this car running as quick is I can which is why I don't want to start saving money up cause it will be 2006 before that happens.
