Old 12-11-2005, 10:24 PM
MexRocket's Avatar
MexRocket MexRocket is offline
Thumbs down Not the head gasket... read this post
http://www.dsmtalk.com/forums/showth...26#post1282726
i posted an update of the mysterious problem with my car.... if the link doesn't work let me know, i really need some suggestions badly because... this is just flat out weird!
STATUS: Near completion for the Engine
PROJECT BEST 1G IN IL:70% Done
MODS: C2 boost,mbc,B16GEGTurbo,12x28x3x3 FMIC,Ported2gmani,k&n.
Being bought in two weeks: Dsmlink,880's,3"exhaust,piping,suspension,axel,dri lled and slotted brakes.
Old 12-11-2005, 10:32 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: Not the head gasket... read this post
I'm going to guess the turbo. Good compression, good oil, my guess is the turbo is good and f-ed up. Not sure though, just my 2 cents.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 12-11-2005, 10:34 PM
MexRocket's Avatar
can you explain why it could be the turbo? lol besides the fact it has cracks in the exhaust part and has shaft play? lol
Old 12-11-2005, 10:40 PM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
I'm totally stumped and annoyed (at aaron) at this point i think aaron lied to get me into his garage . On a serious note the only possibility i can think of is if there is a problem with the oil pump and it caused the oil to be frothy. Coolant in the oil wouldn't go away but frothy oil could go away. Aaron was the white/brown stuff seperated from the oil? Cause if it was than it was water based, if not then it was oil.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 12-11-2005, 10:46 PM
Thor06's Avatar
Jizzed In My Pants
I thought the oil and coolant got mixed out side of the turbo, maybe. Maybe the turbo was leaking oil and coolant and it got mixed in somewhere. Again, it was a shot it the dark, I dont have much experience with turbo troubleshooting. You need a new turbo anyway, maybe just try a new turbo and see if anything happened.
Old 12-11-2005, 10:48 PM
MexRocket's Avatar
well on the cap the white stuff was in the middle, and the oil just surronded it.... there was no oil in the white stuff... like i would mix it and the oil would kinda just swirl in.... but the thing you saw on my tranny from the valve cover hose crap, was mixed together and was alot darker, but on the dip stik it was a white smear... seperate to the oil
Old 12-11-2005, 10:54 PM
MexRocket's Avatar
Well, if you know the turbo is bad and mixing oil and coolant because of bad seals, pull the turbo and either replace it or get it rebuilt. I have a feeling your problem will go away after you get the turbo taken care of.
that is what one of the mods said.... what you guys think?
Old 12-13-2005, 03:50 PM
MexRocket's Avatar
well... i guess no one knows huh
Old 12-13-2005, 08:17 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
Its definity a reason to justify a new turbo for christmass! Frothy oil is typically from ballance shafts coming in contact with the oil. Wich is very unlikely if he didn't over fill his oilpan. Thats a tough one.
DSM geek
Old 12-13-2005, 11:57 PM
MexRocket's Avatar
well, supposudly the shafts have been eliminated... and no i don't fill the oil high at all lol.... when i get that new turbo i'll send you my 14b for 50...
