Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 12-11-2005, 10:05 PM
daniel676 daniel676 is offline
2003 Cobra high speed vibration
New to the board I have a 2003 cobra at about the speed of 120 a very nasty vibration comes in, the car has 22000 miles (I however just purchased). A friend of mine also has a 2003 with the same symptom with only 13000 miles. So far we have ruled out tires/tire balance.
Help.
Old 12-12-2005, 03:57 AM
KimMG KimMG is offline
AF - Advisor
Re: 2003 Cobra high speed vibration
How did you rule out tires and tire balancing? Check to see if any suspension parts are showing signs of wear.
Old 12-15-2005, 07:43 PM
rruddfan21 rruddfan21 is offline
Help.
LOL how often do you drive at 120? if it doesn't happen at lower speeds, i wouldn't worry about it. if you must, though, check suspension components for looseness or wear. also, check out the driveshaft and universal joints.
