Old 12-11-2005, 08:39 PM
Kelhasfun Kelhasfun is offline
heater probs
We have a '96 Ford Windstar GL. My heater works good sometimes however my problem is this I can start up the van and let it idle for 10 minutes and go back out there and it's still cold-no heat at all. But when I start driving it then about 1 mile later it will start coming out?? I've also noticed that when I've drove it for several miles and the heat is coming out just fine, when I pull over and leave the van idling the heat goes cold. Can anybody give me some input about this problem? Or what to check? It's not right and it is cold outside
Old 12-11-2005, 08:53 PM
LeSabre97mint's Avatar
LeSabre97mint LeSabre97mint is offline
Re: heater probs
Is your cooling system full? It sounds like your cooling system is low on coolant so inorder for your heater core to get hot coolant the water pump needs to turn faster.
Check your coolant level.
Regards
Dan
Old 12-12-2005, 08:35 AM
phil-l phil-l is offline
Re: Re: heater probs
...and note wiswind's comments on a similar problem here:
http://www.automotiveforums.com/vbul...d.php?t=491904
Old 12-31-2005, 12:03 AM
Re: Re: Re: heater probs
I checked the coolant level and tested it in the reservoir and there are 5 bubbles floating. So now we check in the radiator cap.
Thank you Wiswind and Phil for all the very helpful info. We will do all that was recommended by all you talented & knowledgeable men and we will post the results. hopefully soon-crazy weather-it's cold (20 F)then 50 degrees the next day often here in Missouri. Happy 2006 to you all! God Bless you and keep you.
Old 06-08-2006, 11:37 PM
Re: heater probs
ok it's summer now in Missouri and the dang a/c is working just fine and cold but it's going crazy (it sucks)It comes out to the floor, then upper vents, then defrost vents by the windshield and back to the floor vents and so on and so on?? So I turn the switch to vents (fan only) until it comes back to us and then back to A/C or Max a/c Any body have any remedy to this problem...????.....?????thanx.. have fun always
