Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 12-11-2005, 06:52 PM
system90's Avatar
system90 system90 is offline
Unhappy cruise won't work
I try to turn on my cruise control and it won't work but there is a green light on it that will pop up I have a 1996 dodge ram 1500.
Old 12-11-2005, 06:59 PM
1thunder 1thunder is offline
Re: cruise won't work
check the vacuum at the servo hose normally rots or gets damaged by battery acid may also damage the servo as it is located below battery tray
Old 12-11-2005, 07:01 PM
system90's Avatar
what does it look like
Old 12-12-2005, 03:14 PM
john m john m is offline
Hi, I have a 97 1500 Ram and had the same trouble. Under the battery tray is the servo unit. It has a cable plugged into it and the vacuum line, which is about 1/8' thick. Mine broke off at the 90 elbow where it goes into the unit. I got a short length of vac-line just big enough to fit the ends into and I used J B Weld to glue it. That was a year ago and it's still working fine. Good luck! John M.
