Go Back   Automotive Forums Car Chat > Honda > JDM Motor & Parts info/chat
JDM Motor & Parts info/chat Discussions on Mugen, Spoon etc. Plus, info on motor swaps (b18 's, b16's h22's etc) and other JDM info!
Old 12-11-2005, 07:17 PM
jdm_crxsi jdm_crxsi is offline
getting ready to put a b16a into my crx si, wut other parts will i need
hi, im mostly doing research on putting a b16 into my 91 crx, i no i need motor mounts, can u tell me everythign else i need to put in it to make it run, thanks
Old 12-11-2005, 09:53 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
Re: getting ready to put a b16a into my crx si, wut other parts will i need
did you try and search?
Team Lonely Drivers
Old 12-11-2005, 10:25 PM
Schister66's Avatar
Schister66 Schister66 is offline
AF -Advisor
Send a message via AIM to Schister66 Send a message via MSN to Schister66
new axles, shift linkage, ECU.....
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR
Old 12-11-2005, 11:08 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
the b16a sir 1 swap is the most common and easiest crx b series swap and has the most info out there on the internet covering it.
assuming this is a drop in an si chassis. parts needed are:
b16a sir 1 engine of course.
cable tranny (Y1, J1, S1, or YS1)
PR3 or PW0 ecu (PR3 recommended.)
mount kit
harness conversion (or wire it yourself)
axles (90-93 teg)
radiator hoses (92 gsr and 90 gsr)
throttle cable (90-93 teg)
90-93 teg rear bracket and two side mount bolts
linkage (cut your own or get it from hasport)
you should also note, that, the engine you get is most likely more than 14-15 years old. if your like me when i did my b16a swap in my old rex, its a good idea to swap out the timing belt, water pump, clutch, oil filter, valve cover gasket, and spark plug O rings. it will save you some headaches down the road.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 12-11-2005, 11:09 PM
AF - Advisor
PS:
if the b16 goes in an HF, you will need 90-93 teg steering knuckles and hub.
in a dx, you need to convert to mpfi.
Old 12-12-2005, 12:33 AM
Schister66's Avatar
AF -Advisor
sounds like you've done it a time or two...
Old 12-12-2005, 12:12 PM
thanks alot, that helped me out alot, one more thing, which is the best website to buy a motor, which is most realiable
Old 12-12-2005, 01:35 PM
AF - Advisor
www.hmotorsonline.com
Old 12-12-2005, 02:16 PM
berkeysi berkeysi is offline
Re: Re: getting ready to put a b16a into my crx si, wut other parts will i need
http://www.osakajdmmotors.com/introhonda.htm
