Old 12-11-2005, 05:54 PM
jstang50 jstang50 is offline
not starting 88 crx
i have a 88 crx that is notstarting i have fire going to it but i dont smell any gas i can hear the fuel pump come on but im out of ideas any help would be welcomed thanks
Old 12-11-2005, 06:01 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
Re: not starting 88 crx
i would take the fuel line off at the engien and see if fuel comes out of the fuel line when you turn the key on. and put it in a jar because alot come out.
if alot comes out then it looks like your injectors. if not then you gotta start tracing back from there.
any codes?
Team Lonely Drivers
Old 12-11-2005, 06:04 PM
pgmfi
Old 12-11-2005, 06:15 PM
pk thanks i will try that no i havent checked for codes but i dont have the check engine light on either
Old 12-11-2005, 06:27 PM
ok no fuel is coming out but i still hear the fuel pump come on you think it could be the fuel filter clogged
Old 12-12-2005, 01:51 AM
CrxFreak91 CrxFreak91 is offline
check the fuel relay under dash and behing change thing
Old 12-12-2005, 03:22 AM
you hear the fuel pump coming on and you took the fuel line off at the fuel rail and no fuel came out.
well start working back from there, take off the fuel line going into the fuel filter and see try turn the key on and see if fuel comes out of there. see what i mean? start working back.
Team Lonely Drivers
Old 12-14-2005, 06:47 PM
there is barely any gas coming out when i turn it on and off a couple time i go to look in the bucket and just a lil bit is in it so im thinking the fuel pump is out or going out so ill take the tank down and see whats up thanks for the help guys
Old 12-14-2005, 08:12 PM
well where did you measure the amount of fuel coming out from?
measure the amount at:
-the fuel rail
-the input for the fuel filter
-go under the car at the trank where the tank line meets up with the body hard line. this one is important becuse if nothing is coming out of there then you gotta worry about it being the fuel pump. oh and spray that thing down the wd40 or liquid wrench because i tried to take mine off and i ripped the hard line and let me tell you its a bitch to replace
Team Lonely Drivers
Old 12-16-2005, 11:02 PM
i got it going guys thanks for all the help
