Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 12-11-2005, 05:11 PM
timmc timmc is offline
97 explorer codes: 1824, 1359, & 1405
explorer has extreme high whine when foot is taken off gas pedal-check engine light codes are: 1824, 1359 & 1405. Also, sometimes won't go in reverse unless in 4x4 low gear. Any help appreciated. TIA.
Tim
Old 12-11-2005, 06:42 PM
mab6680 mab6680 is offline
Re: 97 explorer codes: 1824, 1359, & 1405
this is from a 2000 ford service manual hope it helps you
P1824 = 4WD Electric Clutch Relay Circuit Failure
B1359 = Ignition RUN/ACC Circuit Failure
B1405 = Power Window LF Down Short Circuit to Battery
Old 12-11-2005, 07:11 PM
Re: Re: 97 explorer codes: 1824, 1359, & 1405
thanks for the quick response-it must be the clutch relay that is making the noise.
