Go Back   Automotive Forums Car Chat > Mercury > Villager
Old 12-11-2005, 04:55 PM
MoRon1 MoRon1 is offline
93 Villager door locks when closed
I just bought a 93 villager and when I close the drivers door all the doors lock automatically. Does anybody have any ideas?
Old 02-07-2006, 07:36 AM
PAPABEAR76058 PAPABEAR76058 is offline
Re: 93 Villager door locks when closed
I know this is an old post but here ya go. Mine started doing the same thing and I replaced the relay that is under the radio and it went back to working fine.
Old 03-16-2006, 03:02 PM
wyattran wyattran is offline
I am having the same problem. Could you give me a little more information on the relay, how to find, is it a snap on relay etc. Thanks in advance for the help.
Old 03-25-2006, 01:10 AM
Stevo2's Avatar
Stevo2 Stevo2 is offline
Here's what I see in the wiring diagrams. There is no actual relay by itself but there is a Power Door Lock Control Module.
Power Door Lock Module : Below center of I/P, mounted on center I/P support bracket --- C283
Before you replace it, you might try removing the door lock switch in the drivers door and then slam the door a few times. Maybe your switch is old and has loose contacts inside that make and break when the door is closed?
Jack of all trades...Master of none!
Could someone please fix my Instant Email Notification?
Please get back to us with your fix!
Why did you buy a $40K vehicle and not a $100 Factory Service Manual?
Old 03-25-2006, 06:28 PM
manythreads manythreads is offline
I have the same problem in my 94(among a host of other problems), I will try the driver side switch thing, but also what is the I/P?
Old 10-11-2006, 11:33 AM
cocoz cocoz is offline
My 94 has been doing it for years, I just think of it as a security system. Anybody know where the speed sensor is, my speedometer and odometer wont work anymore. Plus I could use a center lightbar (between the headlights) and a passenger cornering light.
Old 10-24-2006, 09:36 PM
rsmith8411 rsmith8411 is offline
I had a rough time finding replacement bulbs for that lightbar. Nobody seems to cross reference it. The dealer wants $11 apiece! Here's the deal: I got mine at Autozone. I had to call several of them because not all of them carry this item, but the part number is Sylvania 2040. They were only $2 - $3 each there. I think it takes 4.
