Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '96-'00 Civic
Old 12-11-2005, 03:21 PM
smith86 smith86 is offline
99 civic si problems
i have a 99 civic si. ive been having problems getting it started since its been cold. if the engines already warm, itll start. if not, it takes a really long time or doesnt at all. ive had to clean the spark plugs every week for it to start at all, because of the amount of buildup on them. when i try to start it, itll make some wierd sounds, squealling sometimes, and almost like a backfire from the intake. i bought the car this summer and didnt have a problem with it until it got cold. any suggestions? thanks.
Old 12-11-2005, 04:22 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
Re: 99 civic si problems
when it is not starting, you need to check for power, fuel, and spark. work your way from there.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 12-11-2005, 07:51 PM
i have spark and power, but the fuel is an issue. if the car sits too long long, the fuel pressure gauge on the regulator goes down to zero. other than that, it reads fine, if i crank it, it jumps back up to the 30s/40s... not sure exactly what though. somewhere in there. and i also think its running rich, but not sure. the residue on the plugs give me this idea, also when it kicks into vtec it gives off a black smoke.... replaced the o2 sensor... not sure where to go from there.
Old 12-22-2005, 09:51 AM
74 G/A 74 G/A is offline
Check the battery. Seems they will crank but not start when the battery goes bad.
