Old 12-11-2005, 01:06 PM
hiduke89's Avatar
hiduke89 hiduke89 is offline
Send a message via MSN to hiduke89
Engine keeps flooding
Ok well a few weeks ago i posted a bunch of posts on here on my 89 cherokee striaght 6 4.0L, not starting. We figured out that it just keeps getting flooded. What could be causing this to happen? Could it possibly be the fuel pressure regulator or any sort of vaccum with that, i ask this becuase over summer i just replaced it and i might have not installed it correctly.
89' Jeep Cherokee 4x4...(A.K.A.-Daisy)
4.0L Inline 6
4" lift 32"tires
Old 12-11-2005, 11:51 PM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
Re: Engine keeps flooding
it could be that or you have a leaking injector that continue to drip fuel even after you've turned the engine off.
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
Old 12-28-2005, 02:31 AM
oljeeptek oljeeptek is offline
Re: Re: Engine keeps flooding
Did you get anywhere on this?
Remember...
Old Jeeps never die, they just sometimes look that way!
Old 12-31-2005, 01:49 PM
hiduke89's Avatar
Re: Re: Re: Engine keeps flooding
Sorry but no...i took it into a mechanic and they had it for a couple weeks and then just gave me a call and said it was runnin fine now but they don't kno what the did.
4.0L Inline 6
4" lift 32"tires
Old 12-31-2005, 04:45 PM
Doesn't sound like much of a mechanic.
I'd also check for good coil output. A weak ign coil can let it flood when it sits out in the cold. You should be able to get a good blue spark to snap at least 1/2".
Remember...
Old 01-12-2006, 03:27 PM
nova2dr nova2dr is offline
Have you had the battery disconnected at anytime?? If so you need to disconnect it again and let it sit for a few minutes then crack it,shut it off and crack it again....Similar problem I had....
hope this helps....
