Old 12-11-2005, 12:14 PM
snowcobra99 snowcobra99 is offline
!999 Blazer 4x4
Hi haven't been here in a while.Anyway I have a 1999 Blazer 4x4 or ($X$).lol.My problem is its blowing the atc fuse.It blows it at ramdom and i don't even have to push any buttons.I have no codes and when i put in a new fuse it works fine.Anyone ever ran into this?Bill
Old 12-11-2005, 02:42 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: !999 Blazer 4x4
Atc?
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 12-11-2005, 03:08 PM
Re: !999 Blazer 4x4
I'm not sure what atc is.it's in the main fuse box under the hood.My 4x4 buttons lights go out 4x4 will return to 2hi and that fuse is blown.I replace the fuse and it all works good till it desides to blow again.I could blow at any time does't seem to have ryme or reason.I traced some of the wireing for short and found nothing.
Old 12-11-2005, 03:09 PM
Re: !999 Blazer 4x4
I'm not sure what atc is.it's in the main fuse box under the hood.My 4x4 buttons lights go out 4x4 will return to 2hi and that fuse is blown.I replace the fuse and it all works good till it desides to blow again.I could blow at any time does't seem to have ryme or reason.I traced some of the wireing for short and found nothing.I have a mt2500 scaner if the fuse is blown theres no communacation.if its working i get no codes.
Old 12-11-2005, 04:03 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: !999 Blazer 4x4
http://members.troublecodes.net/crunch/99atffuse.pdf
The link above shows the wiring diagram and the ATF/ATC/auto transfer case fuse.
I would check the amp draw on the shift motor to start with and wiring going to it.
MT
MT
Old 12-11-2005, 04:07 PM
mike2004tct's Avatar
mike2004tct mike2004tct is offline
Re: Re: !999 Blazer 4x4
[quote=snowcobra99]I'm not sure what atc is.it's in the main fuse box under the hood.QUOTE]
Where under the hood. Your fuse box is on the drivers side of the dash, isn't it?
atc, "automatic temperature control" or
"automatic transmission conFUSEd"
Old 12-11-2005, 04:21 PM
MT-2500's Avatar
AF - Advisor
Re: !999 Blazer 4x4
^^^Mike open the link I posted.
It is on top of left front fender.
MT
MT
Old 12-11-2005, 04:54 PM
MT
Ok, tried it, but I'm getting a blank screen. (even defeated my Firewall and pop-up blocker to no avail...)
So, did the fuse block location change from '97/98s? I'd guess yes from what you posted.
Old 12-11-2005, 06:23 PM
MT-2500's Avatar
AF - Advisor
Re: !999 Blazer 4x4
Mike
The link is giving me trouble to. Try it later also it is in a pdf.
On the 99 they have a underhood fuse block and a under the dash fuse panel both.
The ATC fuse is in the under hood fuse block.
MT
MT
