Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 12-11-2005, 10:49 AM
heathermm00 heathermm00 is offline
Send a message via MSN to heathermm00 Send a message via Yahoo to heathermm00
2002 Explorer power window doesn't work
One of the back windows stopped working. I read that I should look at the fuses first but I have no idea where I would find them or what to look for once I find the fuses. If it's not the fuses then any ideas on what's wrong with it? It is just the one window that doesn't work the other three work just fine.
Old 12-11-2005, 01:03 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: 2002 Explorer power window doesn't work
If only one of the windows quit, it is probbly not a fuse issue. More than likely it is a switch or motor problem. Have you tried to work the window from other switches? If you have and it still does not work, remove the door panel and check for current at the motor connection. If there is current there, motor is probably bad. If there is no current at motor, probably the master switch.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
