Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 12-11-2005, 10:43 AM
aurorakid aurorakid is offline
I need HELP, Blown Head Gasket repair kit
HI Guys,
I have a 1996 Aurora w/a Northstar Motor.
I have water in my oil and water coming out of the tail pipes.
I don't have the money to have a new or used motor replaced so I decided to try a repair kit from R X AUTO. The repair kit is called THERMAGASKET. I can afford 129 dollars but not $5000. I have no experence in doing something like this but maybe with a little help from you i may get by. I love my car. It says the cooling system needs to be drained and flushed,how do i do that? I will need to change the oil and filter a few times, also remove the thermostat. Wheres the thermostat?
I plan on doing this tomorrow Monday 12/12. I've been surfing the net for answers and could not find any info till I came to this forum thank GOD. Please help me if you have time. [email protected]
Tony
Old 12-11-2005, 06:29 PM
oldsdad oldsdad is offline
Send a message via Yahoo to oldsdad
Re: Blown Head Gasket repair kit
Tony welcome I have sent you detailed instructions to your email good luck and let us know how it turns out.
Mike
Old 12-11-2005, 08:35 PM
Indy8's Avatar
Indy8 Indy8 is offline
I love the title of this thread! It has the potential to be hugely entertaining.
Quality isn't expensive, it's priceless.
Old 12-12-2005, 07:34 AM
rodtice's Avatar
rodtice rodtice is offline
um, if you don't know where the thermostat is I have to question your mechanical abilities to replace a head gasket, especially on a northstar design. Good luck.
Old 12-12-2005, 09:39 AM
apollo7879 apollo7879 is offline
LOL, he's not replacing a head gasket, only adding some stop leak!
Hope it works for you aurorakid.
Old 12-12-2005, 11:37 AM
rodtice's Avatar
oops my bad, in that case let us know if your find a miracle cure.
Old 12-12-2005, 01:35 PM
This morning we took out the t-stat, drained the coolent what was left of it and flushed out the system engine and heater core for 2hrs to get all the antifreeze out. this afternoon we will fill with distilled water and run motor to temp and let cool 3 times, this will get any air that may be traped out.
Then we will put in the Thermagasket A & B Mix and see what happens. Hopefully it will fix the haedgasket leek.
Thanks for all you help and info via e-mail.
I am taking pics as I do this so I may have some to share via e-mail.
[email protected]
Tony
Old 12-12-2005, 06:29 PM
Look like it worked no more steam out the rear and no water in the oil. I wa able to take it for a hyhway ride for 20 miles and was done by 4:45pm. Tomorrow I will take a 200 mile trip and then another 200 mile on wedsday. I will change the oil each time. If you would like to speak with me e-mail your # to me.
[email protected]
I have pics if anyone is intrested. send me your e-mail address and I will forward.
Tony
Old 12-13-2005, 07:37 AM
baron1701 baron1701 is offline
WOW, NO WAY. I WOULD RATHER LIKE PICTURES AND ANYTHING YOU HAVE ON THIS, MY EMAIL IS - [email protected]. THANK YOU AND LET US KNOW IF THIS HOLDS UP.
