Go Back   Automotive Forums Car Chat > Mercury > Cougar
Old 12-11-2005, 11:05 AM
jobartel jobartel is offline
99 Cougar Plastic Fuel Lines
So I could clean the intake, I wanted to remove the fuel injector rails along with the intake. In doing this, I had to disconnect the fuel lines. What I found was that the fuel lines are plastic covered by the normal hose type fuel line. I had to cut mine to get them off.
Can I replace with just the normal fuel line or do I need to go to Ford and buy OEM type?
Old 12-11-2005, 01:01 PM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
You can just replace them with some high pressure fuel hoses from Napa.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
