Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 12-11-2005, 10:58 AM
realjoe2000 realjoe2000 is offline
Question 02 bonneville heated seat
Looking for a direction or answer to a heated seat problem in my 2002 bonneville. Something doesnt work. When heat switch is activated it starts and shuts off in a few seconds. I noticed a black box mounted under the seat clicks when you activate the seat. Would I look at replacing this relay box or could the elements be burned out. Dont know where to start. Thanks
Old 12-14-2005, 09:31 PM
randman1's Avatar
randman1 randman1 is offline
Re: 02 bonneville heated seat
I'm guessing here as I don't have heated seats. The controller monitors the temp and will cycle power to the elements just like an electric blanket or heating pad. Can you heat the relay(s) cycle on/off frequently (faulty temp sensor)? Have you noticed a problem with the passenger's side (control module problem)?
Old 12-17-2005, 10:29 AM
Re: Re: 02 bonneville heated seat
I have cycled the switch many times but allways shuts off after 3-4 seconds. I'm mostly trying to find out if its a relay problem or element problem. No problems with the pass seat, but doesnt get the constant use the drivers seat gets in MN here. Thanks for your reply.
Old 02-26-2006, 05:59 PM
truc0011 truc0011 is offline
realjoe2000, did you ever find a solution to this problem. I am having the same problem with my 2001 SLE. I turn the heated seat on and it goes off in a few seconds, the passenger side works fine.
Thanks.
